blade SR Huey main rotor blades tightness?
    Just a casual observation, but on the video, I noticed that the as the swash plate moves up and down, so does the flybar cradle. Is that supposed to happen? There is a hole in the sleeve that the flybar assembly is fitted to, that slides up and down over a hole through the mast. Should there be a bolt through it? Forgive me if I am wrong but I know nothing about Blade Heli mechanics.
    Graham
    Titan X50E Bavarian Demon 3SX
    Trex 500L Bavarian Demon 3SX
    Trex 450SE Flybar
    Futaba 14SG
      I thought that too.
      the hole doesn't go all the way through so if there is a bolt it must be a tiny one.
      I'll try and find out somehow.
      Before i fly it!
      Trex 450L Dominator (flown six times crashed twice)
      Blade 230s (my hard working trainer)
      Blade CPS (for smashing into walls)
      Blade SR HUEY (too scared to fly at the moment, the 230s is going to end up in here)
      Phoenix Sim
      DX6i
        If you fixed the flybar cradle to the mast with a bolt then the swash would no longer be able to rise and fall (because it's fixed to the cradle with two rigid links). So you would have no collective control and the servos would stall and burn out... Not good!
        I've never built a flybar head (terrible admission to make!) but i'd assume that hole is intended as a reference point for setting the head up.
          Ok so it's all good then. one of the servos is making a buzzing noise at full pitch. Does that mean i need to adjust the swatch so it's in a different position?
          I made it straight with the zip tie method and it looks spot on.
          Phoenix Sim
          DX6i
