Any way to loosen thread lock?
    yep as said Thorpe are good tools as are swiss/ hudy tools fit very good , just a suggestion something els worth buying is HOT00004 450-500 Feathering Shaft Wrench their are other makes but a very handy tool, to hold the shaft with out damaging it while u undo the other grip bolt .
      Originally posted by pug907 View Post
      Forgive me if I'm wrong, but red is/was(in my engineering days) the weakest one, then blue, (stronger) and then green, (you may as well have welded it on). Just checked my bottles (catering size lol) and they are as I have suggested, or do you mean use a stronger one than red on the clutch??
      My understanding is it's
      Purple : weak
      Blue : medium
      Red : Strong
      Green : Seriously strong! :-D
      eg. http://www.permatex.com/products/Automotive/thread_compounds/a_threadlockers.htm
        My bottles are getting on a bit to be fair, but my red loctite is weak. I guess the only answer would be to read what is says on the bottle huh?
        Andy
        Logo 600 SX
        TT E700
        Synergy 516
        Vcontrol
          You can't rely on the colour to determine the strength, unfortunately, you need to use the grading.
          Trex 450 Pro
          450SEV2
          mCPX
          Recycloquad (tm)
          Edge 540 Foamy
          AXN Floater Jet
          MDC F-14 Tomcat
          Depron BAE Hawk
          www.thedailymice.com
            Acetone can be used. although it doesn't actually remove loctite, the acetone brittles loctite thus reducing its strength.
            If the part is aluminum care needs to be taken as using a heat gun on threaded aluminum isn't a good idea. Most aluminum derives its strength from elevated temperature aging. Even a lowly heat gun can over age heat treated aluminum, causing it to lose most of its strength.
            Blade McpX - 130X - 450 3D
            450 pro HobbyKing - 450 Esky Belt CPX
            Esky lame V4 - Nine Eagles 328
            Spektrum Dx6i - Hitec Aurora 9
              I now have a couple of better quality Allen keys... but I have also just found this thread... seems I'm not the only one having the problem...
              These Super Tight Feathering Shaft bolts and the stupid FS Wrench - HeliFreak
              I'm beginning to think that I should just leave the soft black head dampers in and not replace them with the hard red ones... at least for the time being anyway. I'm thinking that since I'll not be attempting anything crazy for a while, I probably wouldn't notice the difference in the dampers anyway - except that the red ones probably make for a less forgiving but more responsive flight... if I'm honest with myself though, a more forgiving flight is probably a better option for me anyway.
              I wanted to change the dampers, because I read that the black dampers are too soft and to swap them out for the red ones immediately - but then, the person that wrote that seemed to be a 3D guru. Anyway, I guess I shouldn't act on everything I read.
              Thank you to everyone who contributed to this thread, I have learned a lot - but I think me resolving my thread lock problem might be a battle for another day... a day when I really will notice the benefits of changing the dampers... which, let's honest, could be a while.
              Current: Gaui X5 FES (Spartan Vortex) : Trex 450 Pro DFC (BeastX) : Blade 130X : Blade mCPX : Blade Nano CPX
              Sim: Phoenix v4
              TX: 14sg : DX7s
                To be honest, i'd want to make sure I could get them out ASAP! The dampers wear on their own and you will need to get them out at some point.
                SAB
                Trex 500 FBL /
                Beast X
                Futaba 8FG
                Proud Owner of 2 EGS Awards
                  Thorpe and Hudy I'd agree with, but the Swiss tools I got when FL first started carrying them are easily the worst investment I've ever made.
                  The best fit I've found was one of my less expensive purchases, the Align brand drivers.
                    I would like to know if I can get them out, but at the same I'm I thinking that I should probably get a few flights out of it before contemplating undoing the head, given the risk that I could damage something.
                    Sim: Phoenix v4
                    TX: 14sg : DX7s
                    • #25
                      Entirely your choice
                      SAB
                      Trex 500 FBL /
                      Beast X
                      Futaba 8FG
