What mini heli?
    cant wait to get it home
    cant really open it in the office :P
      Originally posted by Sheldrake View Post
      You certainly don't hang about! looking forward to a vid?
      video to come!
        You will just love it!
        Trex 450 SEV2
        Trex 450 Pro
        Tarot 500ESP
        mCPx
          - hopefully!
          Originally posted by CPN
          Hi Tom,
          Check that the mcpx is set at 0% pitch at mid throttle, many of them are shipped with far to much negative pitch.
          Its a great heli.
          how would i check this?
            Simple. Look at Blade mCP X - EFlightWiki and scroll down to Pitch Setting Limits section.
            Trex 450 SEV2
            Trex 450 Pro
            Tarot 500ESP
            mCPx
              cheers will have a go tonight!
                I'm struggling for it to take off. When I throttle the blades spin but it doesn't lift up
                  Sounds like too much negative pitch. Mine was like that out of the box, wouldnt lift off even at full stick. Have you checked the pitch of the blades as per the posts above?
                    Just git it working pitch was N not R
                    Just been hovering this thing is amazing. I'm pendulimng too much though :-(
                    An amazing purchase!!!
                    • #25
                      Just wait til you get it outdoors! (over grass!)
                      Trex 450 Pro
                      450SEV2
                      mCPX
                      Recycloquad (tm)
                      Edge 540 Foamy
                      AXN Floater Jet
                      MDC F-14 Tomcat
                      Depron BAE Hawk
                      www.thedailymice.com
                      • #26
                        I'm not a pro just learning to hover.
                        I'm using pitch curv of 75-75-85-90-100
                        Seems very stable
                        • #27
                          That pitch curve is a bit off.....
                          Pitch curves and throttle curves are a matter of personal taste but that one is almost fixed pitch.
                          Something like (for normal mode)
                          Throttle curve: 0, 50,80,90,100
                          Pitch curve: 30, 40,50,80,100
                          Those can be tweaked to taste. You want 50 at mid stick for sure, a bit of negative (below 50) below mid, and full range above.
                          With throttle curves you want a high head speed above mid stick (where pitch goes positive and you get lift)
                          Trex 450 Pro
                          450SEV2
                          mCPX
                          Recycloquad (tm)
                          Edge 540 Foamy
                          AXN Floater Jet
                          MDC F-14 Tomcat
                          Depron BAE Hawk
                          • #28
                            Just testing these very snappy!!!
                            Although when I dethrottle
                            It slams to the ground. Mine are nice and soft
                            • #29
                              Yeah, you need to be careful dropping the stick.
                              You can increase the 2nd throttle point a bit, say 60. Try that, it will slow the drop. Can also increase pitch points 1 and 2 to say 35 and 43, again will slow the drop.
                              Either way, you want to keep head speed as high as possible and only use pitch to ascend/descend. When you're outside and there's a breeze, having your original pitch curve may cause the heli to fly off to the next county....
                              Trex 450 Pro
                              450SEV2
                              mCPX
                              Recycloquad (tm)
                              Edge 540 Foamy
                              AXN Floater Jet
                              MDC F-14 Tomcat
                              Depron BAE Hawk
                              • #30
                                Ok testing now
                                Best to learn with your settings then??
                                Here's me
                                Blade MCPX v2 - YouTube
