dampers were fine after a bit of tweaking they came in track thats all the probs we had tracking but on the 600 we had to up the swash mix but that is flybarred
Spin Blade Problem
I've not adjusted it - I'll have another look when I get home.Originally posted by Asid View PostDifferent blades have a different affect on the control loop. As with all FBL systems you must adjust the FBL loop (gain etc) when changing blades
As already said 12 oclock is not default. That is too high. 9 oclock is default.
Check balance of blades.
Raptor 30V1 Maverick Head
OctoCopter
Futaba 14SG
Mark what the guys are saying is definately your problem mate, just to clarify even further
im guessing it depends what way you have it mounted and how YOUR looking at the unit, maybe your actually already at 9'0clock if you havent touched it Mark? In that case then id go with mis-matched blades (balance/cofg) or dampners.
