What charger do you have Ben..
electric flight is taking over my life
I've just bought a Turnigy Accucel 8150 from Hobby King as I'm getting a little bored of charging my 6S 5000mAh packs on my 2 x Imax B6 chargers. It's an 8S 150W charger, so I whould be cutting my charge times down by two thirds in theory.
Was only £38 delivered (ok, it's taking it's time to arrive) and whilst waiting on delivery, I've stripped out an old desktop power supply which does 160 watts. This is merrily supplying 12V at 11amps to my two chargers now, so was worth doing. Took all of ten minutes to convert. Got my eye on a 500W server PSU on an old server that's due to be scrapped next week. And it's got two of the buggers in it mwahahaha....Growing old is mandatory...growing up is optional!
Trex 600E
Blade MCP-X
Dx6i/Chainlink UHF
Sorted, got a Lipro quad 4 x 3 cell at once
with a psu (cheers Kel)
Still got my turnigy for the 6 cell
Jut got to stop buying batts now
LeeCrashing is in my blood, were can I get a transfusion
You can never have to many batts
Flasher 500
Trex 450v2
Dx6i
Purfleet Model Helicopter Club member
glad you got it ok mate :0) you can charge 6s on it i have done b4 but they only charge at 2.2 amps and take a bit longer but still 4 at once :0) enjoy mateOriginally posted by stumpe View PostSorted, got a Lipro quad 4 x 3 cell at once
LeeKel Velocity 50 sk-720 ,Fusion 50 v-bar pro 5.2 ,Velocity 90 v-bar pro 5.2
& JR DSX11 ,Phoenix and a fridge full of bottled water
RCHA Courier Services PM for Details
www.parcelshipper.co.uk and www.impactexpress.co.uk
Given I've sacked nitro for this year I am looking into a big angry charger, with an eye on the Voltz or Hyperion jobbies. Meanwhile I just got a couple of HP server PSUs off fleabay for £19 each, capable of about 58amp at 24v (2 x 12v in series) . I should be able to weld my next heli together, if nothing else.
go for the Hyperion 1420i net 3 its a great charger upto 14s at 20amps if you cells can accept it and can be powered upto 24v :0)Originally posted by Goto View PostGiven I've sacked nitro for this year I am looking into a big angry charger, with an eye on the Voltz or Hyperion jobbies. Meanwhile I just got a couple of HP server PSUs off fleabay for £19 each, capable of about 58amp at 24v (2 x 12v in series) . I should be able to weld my next heli together, if nothing else.Kel Velocity 50 sk-720 ,Fusion 50 v-bar pro 5.2 ,Velocity 90 v-bar pro 5.2
Parallel is how I do my 12s packs on the Hyperion it's fine as long as the batts are the same type and have been discharged the same theres no probs ;0)Originally posted by p4ddy View PostI'm not keen on fast charging above 1C although i have accidently charged my 2s Nanotech's at 4C without issues (they're rated for 5C max) I may have a crack at parallel charging though
Sent from my iPhone using crapatalkKel Velocity 50 sk-720 ,Fusion 50 v-bar pro 5.2 ,Velocity 90 v-bar pro 5.2
