What is the best Trex 500 Clone!
    if the screws are crap then that really is a true clone
    this is the one waveydavey mentioned Andrew
    PhoenixTechUK and as the guy actually is a forum sponsor, your best bet as far as back up is concerned
      I've just noticed the Avatar Ron, class.
        $34.00 about £22.00, I figure there's a reason why its £250 cheaper than the real thang! Its probably crap!
        You pays your money, you take your choice...
        HobbyKing Online R/C Hobby Store : HK-T500 CCPM 3D EP 500 size Helicopter Kit (Align Trex 500)
        Guy
        And an E.G.S!
          Aaaaaaallllllllllll ppppllllaaaasssssttttiiiiiiccccc
          Cheers Al
          Cosworth, making supercar owners look like co*ks since 1986
            The tarot is mean to be good, link to a thread about it. Pics start on page 2
            Tarot 500 ESP build thread - Heliguy.com
              Easy, Buy the real thing and dont be a skin flint If it ain't in a Trex 500 box, then it simply isn't a trex 500.
              As Alexsandra would say "SIMPLES"
                Originally posted by AlignTrex View Post
                Is the HK-500CMT any good or the EXI500 any good.
                Right here we go,,,
                I had a Trex 500 using a 6s x 13t pin which worked out alot of bucks
                Yes it flew very well and could out fly my lowley skills;
                I put it in an Airwolf and that flew very well until the Align Esc cought fire
                Completely burnt out the main gears, three servos and most of the cyclick ball links, anyway ended up getting a HK 500 complete with servos and esc
                for around £130.
                Had about 25/30 flights with it up to now and apart from a few issuse with the tail linkage I'm very happy with it and would not buy another Trex500.
                If your not going to fly full, hard, 3D then I cannot see the point in forking out for the Trex and you get metal main shaft bearing mounts with the HK
                its an upgrade for the rex,
                Tripler/Helipete/
                "I love the smell of nitro in the morning" & the odd electrickery thingy's
                  Right my two pence worth , i also have a Hk500 running 6s and i love the hell out of it although as i said the fixing hardware is a bit poo , It has a full cnc head and tail out the box CF is a little on the thin side but as everything is interchangable then it's not a problem to swap out .
                  Cheers Al
                    I think your better of buying a second hand "Align" Trex, than a new clone,
                    That's if it's down to cost
                    Grahamc
                    Phoenix,
                    Futaba T8FG,
                    Spektrum DX7S,
                    Blade 130x
                    Trex 250,
                    Trex 450 Pro
                    Trex 600 Pro unbuilt in the box
                    Trex 600 NSP FBL BeastX
                    Trex 700 LE FBL BeastX
                    Some Fixed wing
                    • #25
                      Personally I would buy a HK500 (the CMT or whatever the latest version is). You'll need to spend about another £20 quid on align parts to replace the "definetely fail" parts (see loads of threads).
                      I would then see your first crash as "a cheapie" and just replace parts with Align as you need to. If you never crash then hey the clone worked fine for you the whole time.
                      From what I've read - the EXI / flasher / Tarot / HK are made from the same moulds by a company called Syma or something (theres stuff about who actually builts it in China in another forum...). I would buy HK as 1) cheapest and 2) they shift the highest volume, so I would trust them to out more pressure on their suppliers to sort out issues, and also have fresher stock.
                      <takes_cover>
                      Velocity 50 (OS 55)
                      Trex 600LE (OS 50, quick uk bits)
                      Trex 500 (DS520s all around, fl760)
                      Trex 450 (hs65mgs, ds420 tail, gy401)
                      Trex 250 (stock)
                      • #26
                        Merry Christmas,I'll play nice while it's the season of goodwill :-)
                        • #27
                          Get yourself an Align Trex, AlignTrex.
                          Sam
                          • #28
                            where is he?
                            • #29
                              Originally posted by Biggles View Post
                              None...just buy an align and be done with it.
                              If you are going to buy something made from cheesium then at least buy genuine cheesium!!!!
                              PMSL
                              - Well said that man!
                              Brian
                              More enthusiasm than skill
                              And proud recipient of 3x sigpic
                              • #30
                                where is he?
                                With the money he save buying a HK he could affored to buy that lovely blue outfit
                                Tripler/Helipete/
