GY401 help please
    Ill not bite there, i was clearly stating that i know almost personally that Tim wouldnt diliberatly offend you mate.
    Phil sounds like you have adjusted your rudder Travel Adjust. Theres a gyro limits pot on the top of the 401... this is what you will use so you dont get the binding you experienced. Leave your rudder travel adjust at 100/100 for now. You can use that later to adjust how fast a piro you want. First though before you do anything you want to find a servo arm that will give you 90 degrees to the servo case in normal rate mode. Next you can either centre the pitch slider or if your going to use rate mode then you will want some pitch on the tail blades to keep the tail centred (trial and error later when flying the model and sliding the servo along the boom). After you have 90 servo arm and correct length then adjust the gyro limits pot on the top of the gyro itself so that you get no binding in both directions. Once all that is done and you have an average gain setting programmed then you should flick the gain switch back and forth a couple of times in quick succession. The gyro will then remember the centre point. If you setup normal rate mode then this can help the servos life as its not constantly adjusting and makes the gyro do its job.
    Hope that helps but if ya get stuck give me a shout and im happy to explain it on the phone for ya.
    Lee
    Lee
    www.raptoruas.co.uk
    www.lee.rcha-uk.com
    www.gensace.de
      Thanks Lee, great answer bud
      DOH, it makes sense now. I never thought of the limit pot on the gyro I can't see myself ever flying in rate mode now but I might as well learn how to do it properly.
      Really well explained Lee
      Phil OB3
      Trex 450SE v2
      Walkera 4#3b
      DX6i
      Phoenix
      http://stratfordgliding.co.uk/
      ...and proud owner of THREE!
        Originally posted by Made2Fade View Post
        Ill not bite there as im above that Mojogoes, i was clearly stating that i know almost personally that Tim wouldnt diliberatly offend you.
        Phil sounds like you have adjusted your rudder Travel Adjust. Theres a gyro limits pot on the top of the 401... this is what you will use so you dont get the binding you experienced. Leave your rudder travel adjust at 100/100 for now. You can use that later to adjust how fast a piro you want. First though before you do anything you want to find a servo arm that will give you 90 degrees to the servo case in normal rate mode. Next you can either centre the pitch slider or if your going to use rate mode then you will want some pitch on the tail blades to keep the tail centred (trial and error flying the model and sliding the servo along the boom). After you have done that then adjust the gyro limits pot on the top of the gyro itself so that you get no binding in both directions. Once all that is done and you have an average gain setting programmed then you should flick the gain switch back and forth a couple of times in quick succession. The gyro will then remember the centre point. If you setup normal rate mode then this can help the servos life as its not constantly adjusting and makes the gyro do its job.
        Lee
        Lee
        Lol.........i know he wasn't / wouldn't Lee as he's a fellow yorkshire man.....by the way nice reply.
        T3ds Gy240 S3153 with trex500 skids and trex500 fin set plus now with hybridized canopy and Mini Titan canopy body post set P# PV0816.........Now owned by MoJo have fun
          It flies
          Yahoooo
          Just abit of tweaking the gain and pitch curve.
          I'm sure there'll be more questions tomorrow, but thanks again for all your help so far eveyone
          Phil OB3
          Trex 450SE v2
          Walkera 4#3b
          DX6i
          Phoenix
            Originally posted by Mojogoes View Post
            Can you please explain yourself busterboy
            Quite easily, As Lee said and as I now state it was not aimed at anyone in this thread or any thread on this forum.
            Its a figure of speech and I can't believe youve never heard it before.
            You need to get out more.
              I'm 47 years old m8 i've heard and seen most things living and otherwise but you should have used it in contexted , if you look back at the post it wasn't
              Originally Posted by busterboy
              There are no stupid questions Phil.
              Its the stupid answers that crease me..
              I don't believe this ^^^^ verse is in the book of known acranisms!!
                Just ignore it, Tims from Yorkshire
                Phil
                  Right well we'll leave it at that then... dont want to make a thing of it just saying dont take it to offence as i know nothings intended. Back to Phils post
                  Glad you sussed it Phil, theres nothing to it really bud. If you need a more detailed explanation just shout mate. Good luck with the maiden flight
                  Lee
                  Lee
                  www.raptoruas.co.uk
                  www.lee.rcha-uk.com
                  www.gensace.de
                    Some really useful gen here guys, many thanks. Now getting read-in before the maiden flight of the new-to-me GY401-stabilised Raptor 50. My plan to check it out is to place the heli on a flat, freely-rotating surface (as used in some Chinese restaurants) in order to check out the settings before getting airborne.
                    Si
                    • #25
                      Lee
                      Thanks Lee. Actually the maiden flight was at 11pm last night in the garden on lights (With training gear on)
                      Had three flights today and all I can say is WOW what a difference to the Bellt CP Absolutely rock solid, hands off in the hover for over 5 seconds, perfect tail response, and training gear off.
                      What a day - still buzzing! I now understand gyro gain, throttle and pitch curves, and am no longer intimidated by the fancy electronics on the DX6i.
                      Needless to say I didn't get alot of work done
                      Phil OB3
                      Trex 450SE v2
                      Walkera 4#3b
                      DX6i
                      Phoenix
                      • #26
                        Congrats Phil .. always nice when it suddenly clicks into place and ya wonder what all the worrying was about .. onwards and upwards now m8e
                        Knight 3D
                        • #27
                          Nice one mate glad you happy
                          Lee
                          Lee
                          www.raptoruas.co.uk
                          www.lee.rcha-uk.com
                          www.gensace.de
                          • #28
                            Yeah glad its worked out for you but do us a faver with no more questions for a while........have fun!
