its the book mark i have but im sure if you have a look about on the web site you may find some thing to do the job if not just make up your own pack its quite easy
Need a 12v rechargable battery very small
Threads by FuturaSE are always a good laugh. There is a lot here that I don't understand (but that's not unusual). What I do know is that if you connect two 9v batteries in parallel you won't get 18volts.Tron 7.0 advance Vbar evo V Control
Originally posted by FuturaSE View Post2 batteries (9v) parallel which gives me an outstanding 18v
Be careful - the EL backlight is powered by an inverter circuit that generates a couple of hundred volts AC to drive the EL panel - that inverter might not like 18V if it's designed for 12V.
Can't you just power the backlight off the TX main battery? Or do you want it switchable seperately?
TTrev
Originally posted by Mike Sanders View PostThreads by FuturaSE are always a good laugh. There is a lot here that I don't understand (but that's not unusual). What I do know is that if you connect two 9v batteries in parallel you won't get 18volts.
2x 9v in parrallel =9v (you add the capacity together of the two batteries eg 120 mah + 120 mah = 240 mah)
if you connect in series then you get 18v
9v + 9v = 18v (if both batteries are the same mah then there is no difference in capacity of the new pack eg 120mah on both you will get a total of 12 mah)
edit:- it should read 120 mah here not 12 mah
and futura was it hurbal fags or hurbal cake today?Last edited by electricsceadu; 09-08-2013, 11:27 PM.Hirobo Turbulence D3
1/4 scale Vario Bell 47 G3
1/3 scale Vario R22
2012 LHC Scale Cup Judge
Originally posted by electricsceadu View Posti was about to say that until i read your post
my mistake seems i was in a parallel universe againSome say my left nipple is the shape of a Raptor canopy.......... And that for fun I chase sheep in wellies 3 sizes too big. All I know is I am 3D Clod
Collector of SAB Goblins
Originally posted by FuturaSE View PostDid find me a nice upgrade 9,6v and 750 mah
Instead of the 9,0 and 175 i do have currently
Its even smaller
WOEHOEEEEE
NOW iv found what i was looking for
Losi: 11.1V 200mAh 3S LiPo: MSCT, Rally: Losi (LOSB9824)
agree at Kev seems there is no other way then going lipo this time
But i cannot balance this lipo ever.. I always have to charge it without balancing.. guess lifetime will reduce because of this but we will see
