I've had this problem for a while now, basically it's this, when you go forward cyclic the heli slightly Crabs it to the left, example, the nose is at the 1 O'Clock position and the tail is at 7 O'Clock, the same goes for going backwards just viser versa.
Plus she "rudder spins" in anti clockwise fast and much slower clockwise, I've spoken to Elite models and they seem to think somethingsgone out of phase, but I was wondering if any of you guys have an idea whats needed to be done.
As I'd rather have a go at home and see if I could have a stab at it, I've checked the swash and that's sitting flat, the guide bar is withing the holder ok and the linkage arms from the swash to the lower rota Assembly are all straight and connected with no probs'
Looking at the heli from Tail In, the left servo does seem to move the swash at an angle slightly, but if I cyclic stick top right on the controller then the s/plate goes forward perfectly, I haven't tried this in flight as I haven't the room.
Any ideas at this stage would be great before she goes back to the shop while under warranty.
Thanks.
Thanks.
