Hi all,
As some of you may be aware, I'm having strange problems with my BeltCP. It hovers fine for couple of minutes, but will suddenly spin the tail out and I'll loose control. Cost me some blades and a feathering shaft so far, so not the end of the world... but something nasty will eventually happen.
Are any of the following normal using the stock RTF kit?
Sitting on the ground rotating the main blades at constant trottle gives stubley different head speeds - you can hear the motor winding up and down
The aircraft hovers for a few minutes but spins, typically nose to the right about 90 degrees in about 500ms, then partly stablises
This instability lasts until I put it down on the deck, wind down and give it a few seconds (5) before trying again
The instability is simular over 4 lipos, although it appears my orginal eSky 1800mah is the general best, a second 1800mah I bought at the same time is the worst and 2 2200mah later ones are in the middle
The ESC (which I suspect) is warm to the touch on the heatsink and coolish hot on the sides closest to the MOSFETs. Certainly not painfully hot.
Controller batteries are charged, the antenna wraps around the tail until the mid-boom fin and then doubles back to the front of the skids.
It appears to have behaved like this from new - obviously at the start I wouldnt have been able to see this.
I've checked linkages and can find nothing loose. I'm flying indoors, so this isnt a wind/weather issue. I'm flying within the ground affect zone - <1m altitude, but can hover for a minute+ so dont think its a terbulance issue.
My gut feeling says ESC at the moment... any other opinions?
thanks,
Lyfe
thanks,
Lyfe
) other than the freakyness. When its back on the deck, I still have full and predicable control of the servos.
and I will keep going till I work out what the fault is as this is one hobby I'm not about to give up with lol as soon as I ruite out the problem I will post it on here
