tail spin on trex 450 plus
  • tail spin on trex 450 plus
    Hi can anyone give me advice please, my trex 450 was hovering well this morning with the tail steady, spooled up this afternoon and as soon as the main blades speed up the heli spins as if the gyros not working.
    how can this happen when its not been touched, I am used to fixed wing and I'm afraid I'm finding the change over quite a journey. please any help would be appreciated.
    best regards
    ray
    What gyro are you using? Does it counter rotation correctly?
    DX8
    Phoenix
    RealFlight 7
    Mcpx BL
    Trex 550 DFC with Vx1n
    Trex 700 DFC Pro Hv with Vx1n
    Zmr250 mini H Quad racer
      hi mate check that the tail belt is not slipping also grab hold of tail rotor blades and check by trying to to turn rotor head and check nothing is loose in tail drive i would say that is where youre problem is not in gyro modern electronics very reliable imho
        Hi Mark, thanks for reply its a GP790 head lock. what is the best way to check the counter rotation is ok?.
        it was hovering ok [thats all I'm capable of at moment] couple of hours before this started to happen.
        best regards
        ray
          Hi, thanks for your reply I will check this out.
          I do appreciate your help,
          best regards have a great day you live in a lovely part of the world mate.
          ray
            You haven't turned it from heading hold mode to rate mode by mistake?
            JR XG 7
              Hi, thanks for reply, I don't think so, how would I have done that?
              kind regards
              ray
                kind regards
                ray
                Have you assigned one of your TX switches to the gyro? if so you could have moved it therefore putting the Gyro in rate mode.
                The Fleet
                Trex 450 Pro on Brain 2
                Mini Titan super Cobra ah1
                Alien 550 Quad.3DR Pixhawk
                Futaba 7C 8FGS 14SG
                Specktrum DX6i
                  You may have a switch on the TX to change from Heading hold mode to rate mode. I know as have taken off in rate mode before and my heli started to piro.
                  Turn it on and move the rudder. It should stay where you leave it and not return back to center when you let the stick go. That might be the most basic way of telling.
                  JR XG 7
                    Hi, thanks for the suggestion, tried that and that seems ok, still got the problem though.
                    many thanks
                    best regards
                    ray
                    Can anyone recommend a guy that would look at for me in my kneck of the woods [lincoln] I would be prepared to pay for the time.
                      what gyro is it
                      The Fleet
                      Futaba 7C 8FGS 14SG
                      Specktrum DX6i
                        Hi, its an align GP790
                        regards
                        ray
                          Ray, there are many possibilities, both mechanical and electronic that could cause this issue.
                          If I was in your situation (and i do remember being totally confused by it all) I would setup a new model on the Tx, bind it to your receiver and start from scratch. I would then follow Finless Bobs Trex 450 videos on how to setup your Tx and Gyro (and all his other vids as they are such good information). Using someone to setup your heli is great, but when the inevitable happens and you crash, you dont want to be forking out again for a setup. Honestly Finless is the way forward!
                            Thanks jez I appreciate your comments.
                            best regards
                            ray
                              Hi Jez, did exactly what you said what a fantastic site finless bob, reprogrammed the tx and gyro and checked every thing as per Bob and she is back to being fit and healthy again. What I don't understand is : the heli is hovering real good, land well, then put her in the garage for a couple of hours then she developes some programming hitch is this possible??????????
                              Any way I would like to say a very big thank you to all you guys for your kind help.
                              best regards
                              ray
