Banked turns.
  • Banked turns.
    Is it easier to do banked turns if you put some expo on the rudder? I find I need such a tiny movement on the rudder stick that the tail can come round quicker than I expect.
    Good idea or should I just get used to it? My interest is sport and scale flying, not 3D.
    Thanks.
    Vikki.
    I use a bit of rudder expo, just 10% or so - but I tend to like things quite twitchy anyway (im more 3d)
    TT Raptor G4 + Vbar
      Nothing wrong with a bit of expo on the tail, if it helps smooth out your flight then use it. I use 55% expo on my Logo rudd which i've been told is bad. I aasked Duncan Osbourn if he uses expo ion his rudd because like me he flies with thumbs & he uses 5% on top of his CSM720 set up. However my expo varies between each model & i don't think i use any on my Gaui 200 & only a smidge on my 450.
        I use 15 % just to reduce involuntary inputs, always have ;-)
          Hi Vicki, If your into scale and sport flying try using rate mode as the tail will tend to follow the heli more with less input from you, Especially scale flying looks more natural in rate mode.
          Keith
          Sent from my iPad using Tapatalk HD
            I have only just started using expo since doing more 3d-esque flying. Funnels are a touch smoother with it as the finite corrections needed are a lot smaller, making it look nicer, plus tic-tocs are smoothed out. Before that I never used it.
            As for circles, it's just getting that sweet spot. Once the heli is moving in the direction and angle you want, you should only really need to make small corrections on the cyclic and tail, it is however, finding that sweet spot I wouldn't bother with expo at this point, because if you're only doing sport type flying you should need it as your heli should be fairly smooth to fly anyway.
            SAB
            Trex 500 FBL /
            Beast X
            Futaba 8FG
            Proud Owner of 2 EGS Awards
              I use 10% on mine. Each to their own, just have a play with different values.
              James
              SEMAS Flying Club
                I think I settled on 12% cyclic and 10% rudder. When I tried 15% it was 'too much', so split the difference lol.
                SAB
                Trex 500 FBL /
                Beast X
                Futaba 8FG
                  As James said.
                  What is right for one is not for another. Personally I don't run expo much at all no more but thats just how i like the feel of it.
                  In this case you could benefit more from reducing the travel or slowing the gyro rate so it slows the tail down as this seems more like the cause of the issue with it being too quick.
                    Thanks ever so much guys. A bit of expo it is then. To be honest, it feels like I need some.
                    Thanks for the info on rate over HH. Is there much difference between the two other than tail following heli?
                    Vikki.
                      Rate mode does really help smooth out the turns whilst learning I found. Just be careful in wind or flying backwards as the heli will want to weather vane in to the prevailing airflow, you have to be ready to counteract that on the rudder.
                      Blade 180 CFX - Stock setup
                      Gaui X3 - Spartan VX1e, 460MX, Savox
                      Goblin 500 - Spartan VX1e, eFlite 550H, BLS153, Xpert SI2201, HW100
                      Hughes 300 - HK450
                      AS350 - Blade 500X
                      BO-105 - TRex 500 Dominator
                      Bell 222 - Stretched Gaui X5 mechanics
                      Jetranger - Stretched X50e mechanics
                      Airwolf - Roban 800
                        If you are in rate mode when hovering for instance and the wind is from the side the heli will turn into the wind but in heading hold the heli will hold heading but will try to move sideways with the wind.
                          Thanks. Think I'll stick with HH, I like it and it's how I'm learning my turns. Expo sounds like it will suit me on the rudder. Just to reduce sensitivity around mid stick.
                            Keith
                            What is rate mode?
                            Dji Phantom
                              ^^Hehe - really?
                              rate mode is.. uh.. how do you explain it? it's the opposite of heading hold. it won't hold your heading. it will just counter any wind pushing your heli but it will not keep your heli pointing the same way. it will just help but eventually will give in to where the wind is pushing it. (sorry my explanation is crap)
