wot does this mean? any help would good thanks
Gear Drive Ratio: 10:4.95/1:11.5:4.95/1:13.6:4.95?
Gear ratios usually describe the ratio between pinion and main gear, and sometimes, they also include the ratio between main gear and tail gear.
eg. 8.5:1 = 8.5 to 1 - the gear ratio of the Trex600 nitro.
So the motor (and therefore the pinion, being attached to the motor) will revolve 8.5 times, for every revolution of the main gear.
RobTeam Align, Midland Helicopters, Optifuel, Cyclone Blades, Scorpion Motors, Thunder Power, Savox Servos, JR Propo
| 3D Championship
i was lookin at a trex 450 and it said about the gear ratio why would some one need to know that is it o do wih head speed or somethin?__________________________________________________
trex se v2
hs-65mg servos
gy401
beam E4
scorpion 2221-6 motor
55a esc
hs--65hb servos
gy401
dx7
Yes, it will affect the headspeed.
You can work out roughly what headspeed you will get based on a few factors on the Trex450 and running those numbers through a headspeed calculator.
These things need to know KV of the motor being used, the motor efficiency, number of LiPo cells being used and the main and pinion gear tooth counts.
| 3D Championship
