The guts of the beast..................
  • The guts of the beast..................
    Hi guys and girls.............
    I've been away from R/C flying now for about 3 years thanks to work and other commitments. However thanks to a recently recieved present of a Raptor 30 from my better half, i'm starting back into it all again.
    I used to fly a little Hirobo Shuttle Plus heli years ago, which i will shortly be heading home to Nortern Ireland to salvage parts from, along with some radio gear that i have stored away somewhere (which should save a small fortune!)
    I have the Raptor 30 kit with the little Thunder Tiger 39 pro engine, which is slowly but steadily looking more and more like a chopper as time progresses.
    Just asking some advice to which components to put into this kit. I already have a Sanwa 6000 Tx and some receivers lying around in old aircraft. Any advice on:
    • What servos would be good to use in this kit and Tx combo to ease back into things, with a view to moving onto some basic 3D flying (if all goes well)
    • I assume that the batteries that i have stored will be long past their best - any advice on good Tx and Rx batteries to use.
    • Finally i think (if memory serves me) i have a CSM gyro - not sure what the exact model is - it was small and blue (i'm sure that helps loads!!!!ahem......), wasn't that expensive, so i'm sure it was a basic model. Is this still likely to be in a good condition to go flying with, or is the chopper likely to end up in a pile of expensive bent metal and ball bearings
    • Can the Raptor be started using the remote battery clip on glow plug device; that you can pull off once started (like those used on aircraft), or will i need to buy one to fix onto the glow plug itself? - I know with the Shuttle plus the clip on starter wouldn't fit.
    Any other advice is gratefully received, as to what else would be useful at this stage - cheap and cheerful is always good haha!!
    If everything seems under control.........you're not going fast enough
    Hi
    If you have the CSM HLG200 gyro, then this should be fine to start with.
    Basic but holds the tail well as long as its setup correctly. I use a Futaba 9404 with mine and the tail is held fine. This is a Shuttle plus.
    I guess most people would say get some decent servo's such as 3152's. These are digital so you need to get a decent RX battery. 2400mAH minimum I would say.
    As for the remote battery clip, this is always a good idea. I use one with the Shuttle and makes life at the field so much easier.
    Mark
    sigpicx2
    Airskipper 50 - For sale
