Fromeco is just the make of the regulator. The pin flag should be able to move to another bit of the heli if you want. Some people do run without switches as they are seen as another point of failure but it means you need to remove the canopy after each flight to disconnect the lipo and anyway the pinflag system is better than a standard mechanical switch. Try not to get involved in all the electronics etc, just fly it.
Trex 600n some basic questions...
The Pin flag won't affect the engine in any way. It also has the advantage of failing to on, this means that if the switch fails it won't kill the power but will stay permanently on. Like Dave said, move it to somewhere else on the heli that won't affect your canopy & go fly
Del
Outrage Velocity 50 N2 FBL, OS55 Powered
-Built and almost ready to fly
Climb-Out
3D Scotland
Proud owner of 2 EGS
i wil consider moving it away from the canopy.. funny place to put it if you ask me..
