Beginner
  • #76
    Ill try it in the morning, thanks!
    -Scott
    Helicopter:
    Blade CX2 -FOR SALE (check it out)
    http://www.rcheliaddict.co.uk/classi...duct=448&cat=7
    • #77
      Originally posted by Scottscott View Post
      And for the next thing, should i;
      1. Buy extra battery, upgrades ect.
      2. Buy Phoenix sim.
      Think you might find the Phoenix a tad expensive.... I bought one....with 2 cable for tx's. £92 !
      *** CX2 with extra Bling *** STATUS
      *** HoneyBee Belt CP *** RETIRED
      *** Phoenix Sim ***
      *** T-Rex 600e 1st REAL Heli :- GY611 + S9256 + 3*S9451, DX7+AR6200, Revolution 4800 20C 6S, Radix 600 *** STATUS
      • #78
        You can use the standard cable for the CX2 transmitter, so should be £80.
        Still cheaper than it's rivals, and cheaper than the repair bill should you jump straight into big helis
        Raptor 50
        Blade CX2
        • #79
          Second flight of the day today and just as i was about to land i thaught,
          "Lets just have another go around the living room, before i have to charge again"
          So i continued hovering at about eye level, then started circling the room which is nothing new. Then suddenly i hit the door, broke two blades one on the top set one on the bottom set!
          Its alright tho, got some new blades in the post!
          Anyway, the morale of the story is;
          Never submit to that "one more flight wont hurt" urge.
          Helicopter:
          • #80
            thats true for any thing one more sweet etc my fav is i'll do one more set of jumps before i go lol
            It's a diesel.
            Maximum output PS 170 at RPM 4200
            Maximum torque 258 lbs.ft / 350 Nm at RPM 2000
            and forever standard
            • #81
              You learn this very quickly Scott my lad, now you know why I said buy a set of upper and lower rota spares, been there done it before and hovered up the splintered blade parts, lol, your be alright, think of it this way.
              "you've learned one more way of how not to fly the CX2."
              sigpicWayne AKA OB1
              Plus 3 Eddie Gold Stars, yay!
              • #82
                Boring weekend- Broken Heli.
                Anyway, iv decided on a plan of action!
                Firstly i am going to buy phoenix sim in a few days, then a few days later (pay dayyy) i will purchase a extra battery and spare blades. Jolly good show.
                -Scott
                Helicopter:
                • #83
                  Haha, that 'One more flight' was the thing that broke my rappy on it's first proper outting. Must be cursed!
                  Glad you have some blades on order at least
                  Raptor 50
                  Blade CX2
                  • #84
                    Just a little update here!
                    Well, this morning Phoenicx arrived (thanks Stuart!) and it really is good! I didnt realise how hard it was to actually fly a model helicopter!
                    Do any of you guys play it online? I connected before, but i think i got kicked from a server as i was flying the Lama!
                    Still no blades here yet... (ordered on saturday. ) So no flying my Blade CX2, i miss it.
                    -Scott
                    Helicopter:
                    • #85
                      I know the joy of waiting for goods
                      Am currently waiting for my scale apache kit to arrive - has been a couple of weeks now
                      Raptor 50
                      Blade CX2
                      • #86
                        Ok wow, how do you guys land these bigger helis? Iv not landed one sucsessfully yet.
                        Also, does phoenix use up my transmitters batteries?
                        Also, how do i do it inverted? i seem to just turn upside-down and fall to the foor? :/
                        -Scott
                        Helicopter:
                        • #87
                          -Scott
                          1: Very carefully nah its just part of the learning process, hovering and landing being the first things you must do
                          2: Yes but if you can take out the crystal it will last longer.
                          3: You should have a switch on the tranny to go inverted, if its the same as mine?
                          T-Rex 500ESP FBL Beastx
                          T-Rex 450SE V2
                          Futaba 7c 2.4ghz
                          • #88
                            without the crystal in it will last loads longer.
                            the switch is the idle up and it basically keeps the motor running at higher rev's usually using curves i.e. when the stick is either at the top or the bottom of its movment the revs are alot higher than when the stick is central and the curve is the progresive line between the 3 positions top, middle and bottom.
                            So at top you may have full revs and +10deg pitch, middle would give you say mid revs and 0deg pitch at the lowest position you may have full revs and -10deg pitch
                            All the best
                            Tony.
                            • #89
                              Ok, whats the crystal?
                              Helicopter:
                              • #90
                                If you're using the Blade CX2 transmitter, there won't be one as it operates on the 2.4ghz frequency
                                Raptor 50
                                Blade CX2
