align esc settings for begginer?
  • align esc settings for begginer?
    i have a trex 450 and a 500 with standard align esc's, ive been looking at the settings in the instructions and wondered what i should have a couple of them set to, as a begginer just hovering.
    should it be on the high cut off voltage protection or medium? and should i have the throttle response on standard, medium or quick speed and last question, should the electronic timing be, low, mid or high with the standard motor. thanks for yr advice
    Trex 500l Dominator
    Trex 450l Dominator
    Mcpx bl
    Pheonix sim
    dx8
    just plug it in and go fly DONT change anything
    Do what u do best
    DX7 and DX8
    Phoenix sim
    And plenty of spare parts
      Go with the manuals bulleted standard settings.
        Leave it as supplied if new, otherwise set it to the following Bleeps:-
        1,2,2,2,2
        TRex 500 FBL DFC VBar Pro Blueline, Standard Align Setup.
        TRex 500 Pro DFC 3GX, Standard Align Setup
        mCPX
        Phoenix
        Futaba 10C
          [QUOTE=bikerflier;684622]Leave it as supplied if new, otherwise set it to the following Bleeps:-
          1,2,2,2,2[/QUOTE
          it wasnt new so at the mo i got 1,2,2,2,1 so only difference is the medium throttle response, mines on standard, cheers, loz
          Trex 500l Dominator
          Trex 450l Dominator
          Mcpx bl
          Pheonix sim
          dx8
            Run with that, it's fine.
            1,2,2,2,2[/QUOTE
            mCPX
            Phoenix
            Futaba 10C
              will do thanks
              Trex 500l Dominator
              Trex 450l Dominator
              Mcpx bl
              Pheonix sim
              dx8
