dampers??
  • dampers??
    i keep reading about dampers grey ones black ones etc etc but dont have a clue what there for and where abouts they are on a heli? who'd l;ike to explain, cheers
    Trex 500l Dominator
    Trex 450l Dominator
    Mcpx bl
    Pheonix sim
    dx8
    This usually refers to head dampers/dampners.. they are located each side of the feathering shaft in the rotor head housing. With or without a spacer between them (depends on design of head. Also some feathering shafts have a central ball).
    The idea is that the rotation of the head and blades isnlt quite as rigid as one might imaging ..needs a little lead and lag as the rotors move from into wind / with the wind/ across the wind (yeah it;s more complicated but I'm simple) as well as some up and down stresses.
    The different damper colours are just a way of coding them and usually manufacturer specific. Damper stiffness is measured in durometers and damper designs vary from simple O-rings to short tube lengths.
    Generally the higher the headspeed the stiffer the dampers need to be to stop head nodding also the longer or heavier the blades the stuffer they need to be.
    For the sake of completeness: some folk also refer to the skid tube rubbers as dampers. You can also get specific skid/under-carriage dampers (JR and QuicksWorldWide).. they are worth consiering for bigger helis anyway..they fit between the bottom plate and skid-bows.. simple a rubber bush with a thread plate bonded each end.. acts as a simple shock absorber for those rough landings and gives an extra small clearance under the heli
    PGK
      ok cheers, and my next question is what is a feathering shaft? lol
      Trex 500l Dominator
      Trex 450l Dominator
      Mcpx bl
      Pheonix sim
      dx8
        That'll be something you tickle the misses with to keep her sweet....
          Lmao
          Its the metal bar that goes through the head at 90 deg to the main shaft and normally has bolts on each end holding the blade grips in place.
          Sent from my Desire HD using Tapatalk
          Paul.
          TD
          R
            Loz
            Download the 500 manual and u will see all the individual parts for each section of the Heli, this will give u a better understanding of the way helis work and what goes were normally helps
            Lee
            Crashing is in my blood, were can I get a transfusion
            You can never have to many batts
            Flasher 500
            Trex 450v2
            Dx6i
            Purfleet Model Helicopter Club member
              pmsl im chasing the missus round the bedroom wiv me feathering shaft oooo errrr, lol
              Trex 500l Dominator
              Trex 450l Dominator
              Mcpx bl
              Pheonix sim
              dx8
                Originally posted by stumpe View Post
                Loz
                Lee
                cheers lee ill have a look for that
                Trex 500l Dominator
                Trex 450l Dominator
                Mcpx bl
                Pheonix sim
                dx8
                  Here u go
                  RC Manual Downloads : RC Bargains, RC Helicopters, Spares, Accessories and Upgrades - Walkera, ESky, Align, Century
                  Lee
                  Flasher 500
                  Trex 450v2
                  Dx6i
                    cheers for that lee
                    Trex 500l Dominator
                    Trex 450l Dominator
                    Mcpx bl
                    Pheonix sim
                    dx8
