I know its a big ask but,does anyone have a diagram of how to install the servos into a spektrum ar6200 reciever?The reciever on my cp gold had number rather than Ele/rud etc.
Jim
Jim
I'm not sure a diagram will help. However you will do no harm using trial and error. You should be able to figure out which are your elevator and gyro leads so stick the lead from the gyro into the RUDD port, the elevator into the ELEV port and just check out all the others.
I'd use a 4.8v power source tho - you don't want the motor spooling up on you if you use the LiPo and ESC to power the Rx.
Martin
I make a short servo extension lead and plug it into Bat/Bind so when the installation is completed and the RX is buried away, it is still easy to re-bind after making settings changes, and connect a standard RX battery for setting up so the motor won't run.
Aux1 is Pitch
Throttle is ESC/bec yes
Edmund All Electric: Tx: Futaba 18mz & Spektrum DX8 Gen 2 for BnF toys Helicopters:Blade mCPX, Nano CPX; T-Rex 250SE; Outrage G5, Outrage G5 FBL; Trex 500 CF; Trex 500 ESP, Trex 500 Pro FBL Small Planks:Multiplex Acromaster, PA Addiction, PA Extra 260, Big Plank:Jabiru SK Chargers: eStation Bantam BC8; Graupner Ultra Duo Plus 50, LiPro Quad 6, Revolectrix Celpro PowerLab 8 v2
I make a short servo extension lead and plug it into Bat/Bind so when the installation is completed and the RX is buried away, it is still easy to re-bind after making settings changes.....
SOOOO simple when you think it through. I have a couple of 250's where, if I had thought to add a short extension, I would have had much less trouble. Time to order some very short extension leads. Thanks.
