Hello folks,
Have been reading and searching the forums. Have got to the point where I crash less than batteries run out, so I'm trying to sort out a field charging battery, here's what's i learnt searching - am i on the right track?
1)You can charge from your car, but its not a deep cycle battery so risk it dies.
2)You can charge from spare car battery, they are cheap, but it will die fast.
3) Need to use a leisure battery that can deep cycle.
4) Needs to be sealed so car doesnt melt on the way to field.
5) Should be as many AH (amp hours) as budget allows.
Questions I could do with some help on
Does the chemistry matter? lead acid / gel packs etc?
How would I calculate what rate to charge the leisure battery on?
Thanks for help / corrections!
Chris.
Chris.
