Was in the process of cleaning the carb and I found one screw removed fine but the head on the other screw was quite damaged (looks over tightened). Any suggestions on removal?
Carb retaining screws
If you can you need to try to cut a slot in the head of the screw with a Dremel and cutting disc.
Then use a flat blade screwdriver to get the screw out.Minicopter Diabolo - V Bar v5.3, Kontronik Kosmik 200 and Pyro 750-56 .
Blade mCPX - now Version 2
Just go careful not to touch the casting itself - it won`t look very nice if you do.Minicopter Diabolo - V Bar v5.3, Kontronik Kosmik 200 and Pyro 750-56 .
K removed the screw by dremmelling and now I could do with a new screw. Anybody know where one can by replacements?
M3.5 x 5 looks like a fairly standard metal thread.
Update, looks like Skyline Models stock them but Fastlads doesn't unless they have generic ones.Last edited by dam74; 24-01-2010, 10:15 PM.Darryl
Eflite Blade MSR
Align Trex 450 Sport
Spektrum DX6i
BMFA Member
I understand the important of asthetics, it's part of my trade. Well for me anyway.
