Currently setting up my Mini Titan, I’ve had to digress from the manual to get this to work:
Had to use the reverse setting for direction i.e heli flying backwards, with this the left / right pitch was wrong so had to swap the servos around to get the collective pitch direction correct. Is this normal? Also at the end of the collective travel -10 - +10, which only uses 60% of the servo travel, the pitch commands are ‘flattened’ by the collective I assume this is OK and prevents the pitch going above 10 degs and the blade stalling??
Need some reassurance here thanks!
