radio system
    which is best mode 1 or 2 guys ?
    proud owners of eddie stars X 2
      If you have never used either then mode 2 is the one you want,
      Mode 1 is for cachanders
      Gaza07
      Trex 500esp 6s Beast-X V3
      Trex 600esp 12s Beast-X V3
      A few Multi Rotors
        Mode 2 for heli flying!
        Both cyclic controls on the same (right) stick
        | 3D Championship
          GOT to swop radio !
          Hi All
          Just got a upgraded walkere 60 (used but ex con)
          But it fitted with iffy r.c (wrong band) Know what i mean !!!
          Picked up a jr xp642 t.x & rev (no book) is has got hel/ac modes.
          Rev in heli is marked 1,2,3,4,5,6.
          On jr rev its batt,aux1,gear.rudd,elev,aile,thro.
          Anyone know what goes where ?
          Save me messin about traceing wires everywere.
          Go on say it lazy so & so.
          Thanks (hopefully)
          John
            quick question
            I was looking at the spectrum dx6 and wondering how on earth it works as it says you dont need a crystal. Would i need to buy a new tx/rx for my heli or use the original one?
              Originally posted by john54 View Post
              Hi All
              John
              How can a Wa*kera be in excellent condition as they are cr*p from new!!!!????!!!!! LOL
              www.lincsheli.com
                I think it scans for a free strong channel then locks into this signal .
                Then rescans every few seconds to find strongest signal .
                Thats why it dont use crystals
                  modern radios don't need xtals necessarily, you can have a synth system in both tx and rx so you can dial in the channel you want to use.
                  Look through this forum and you will find a thread that explains about how the dx 2.4Ghz syatem works, which is a step beyond the syth modules on 35Mhz.
                  There is an rx/scanner in the tx as well as a transmitter.
                  Yuo switch tx on first and it scans for a free slot in the vast number of channels in the 2.4Ghz band.
                  when it is ready you switch the rx on and it tunes in to the strongest signal from your close tx.
                  Thus you can arrive at the flying site and switch on without worry about frequencies.
                  someone else with a 2.4Ghz will not arrive and transmit on your channel becuase their tx will find you are occupying the channel and it will choose another.
                  To have two sets interfere they would have to have both been switched on and working far enough apart to not hear eachother, and then be moved closer together. Plus they would need to be by chance on the same channel.
                  It all sounds great doesn't it!
                  The DX6 system is low power short range - ok for small models.
                  The Dx7 system can also drive the dx6 rx with short range or the two part dx7 rx with full range.
                  If these systems prove to be robust then it will be the way for us all to go because it gives us protection from being shot down which is big fear for those who fly big expensive models in busy places, especially as there a lot of 35 Mhz radios flying out of toy shops at the moment.
                    update guys
                    got a JR x2610 after the advice from you guys thanks .
                    whats the best settings for a newbie like me ??
                    Got a twister 3d
                    • #25
                      Moyesboy
                      I think if you had 2 Dx7`s far enough apart to not interfere than brought them together there would still be no problem
                      As you know,it transmits on 2 channels at once so both Tx`s would have to both be using the same channels as if one is corrupted the Rx uses the other,,also the Rx is bonded to your Tx only so it will disregard another Tx
                      Also i think it may frequency hop but im not sure if this is correct or not
                      Either way,lockouts are unlikely,,the Spektrum land based stuff does not interfere with the air based stuff so interference could only happen if another flier nearby had a DX7 and your model flew within his range,but you need all the above to happen before problems if at all
                      • #26
                        im pretty sure they requency hop so even if your model moved into range of a tx using the same 2 freqs it would hop one then the other to new freqs without you ever seeing it.
                        Ade
                        www.accurc.com
                        adrian@accurc.com
                        This is an apple free zone
