Hi All, I,m just installing the electronics in my raptor 30 and run into a bit of a problem with the gyro/transmitter. The gyro is the 401 and transmitter is the futaba ff9 super CHP. I was following the setup procedure from raptor technique, it all was going fine untill i was programing the trans, the guide says to asigne switch B to control the gyro mode. So i did, in the menu it appears to work fine, but it doesnt change gyro mode. It wasnt untill i knocked switch F buy mistake i noticed it change gyro mode? I have played about asigning the gyro to other swiches but it makes no difference only swicth F will control it? The transmitter and gyro are all brand new and this is the frist time ive tryed changing any of the settings. I would really apreciate any sugestions
