Well I went down to Hobbystores in Southampton with my .30 SC Engine from the Century Hawk Pro that I mentioned in one of the other threads. I was looking at electric helicopters and also getting some tools/essentials for the IC helicopter. The main one being a wrench to remove the nut off the crankshaft however we didn't have much luck with that (found a thin walled socket in a tin of sockets at home that did the job). However the guy that I think manages/owns the store had a look at the engine for me and confirmed my suspicions that the engine had rust damage. He informed me about the IC fuel being a certain mixture of alcohol/oil that it is hydroscopic and draws water/moisture into the piston chamber and causes rusting. We had a look it out in daylight and the wall of the piston has rusting on it aswell as the piston sleeve. You can clearly see it on the top end of the engine but it's a bit harder to see anything when looking in from the front end (last few shots). He seemed to think that the crankshaft bearings would also be rusted aswell. His advice was to bin the engine and get a new one as repairs to it wouldn't be viable/economical.
What do you guys think? Paper weight? Repairable? Or nothing wrong with it?
He said that it's probably been stored away for long periods and had no after run oil applied to the carb/glow plug hole.
Probably the owner stacked the helicopter (lots of other damage that I discovered post purchase) and stored it away and then decided to sell it on eBay to some unsuspecting customer. This helicopter according to the seller was RTF aswell
PS. sorry if the photos breach the forum policies of width/height restrictions. Was trying to get max detail.
