Wobble
    Originally posted by kevinh View Post
    is that you flying in that video mate,
    if so loose the under carriage as you seemed to master the hover both side on a partial side on, you seemd to be able to hover long enough in one place.....
    its a big step i know but you will notice the difference without them!!
    Thanks, yes, it's me.
    Those bits I'm not too bad at - though it was very calm that day.
    I've done loads of indoor hovering with GAUI 100s, 200s (inc a 3 blade with no stabilisation), & a BuzzFly, all w/o TG for ages, so some stuff is pretty sussed.
    What I realised (about 10 minutes after that video - crunch...) was that some stuff I'm clueless at. I'm still much worse hovering nose-right (3 O'clock) than the other orientations (esp with wind), and between 3 O'c & 6 O'c I'm crap. I also lose orientation quite easilly. Part of this is down to being used to flying tiny helis up close and low down.
    When something is 20' away and 10' up, those fluoro balls on the TG give a good visual cue, helping me stay relaxed.
    So for now, I'm banging away at the orientations, and getting the co-ordination sussed.
    I also really must get those canopies on...
    Yes, it's th@ tw@ Scallyb@...
      I know exactly what you mean about the training balls giving you good visual clues, but I found I hated the TG, cos it made the heli unstable.
      Horses for courses, I suppose?
      Brian
      More enthusiasm than skill
      And proud recipient of 3x sigpic
        Originally posted by Brian Gifford View Post
        [...]but I found I hated the TG, cos it made the heli unstable.
        Unstable in what kind of way ?
        Dunno if I said this already, but the 2nd G5 seems a bit cursed, and with the regular TG vibrates to pieces. I've not got to the bottom of this (which has bothered me and drove building the 3rd one), but as I really wanted to have 2 flying I messed about with it.
        One of the 4 fluoro balls fell off in flight, and the heli immediately stopped vibrating. As an experiment, I halved the lengths of all 4 TG spars. This pretty much doesn't vibrate, but does leave the fluoro balls as a visual cue, as well as a slightly wider footprint for bad landings.
        This might be a possibile compromise, or stepping stone ?
          Seems to me that you have a resonance problem with the TG. I had the same trouble when hovering, (although I was hovering a Raptor 50, the principle is the same). After taking advice from Lee (Made2Fade) I shortened the TG Spars by 50mm and kept doing so until the vibration was minimised. The vibes never went completely so I took the TG off and went for it, never looked back. You say you use the flouro balls as a visual clue, would it not be better to train yourself to watch the heli itself for orientation? It is quite a big step to lose the TG so my advice...start watching the heli for your orientations and lose the TG as soon as..after the first few landings your confidence will grow..and the wobble will go
          Terry
          Raptor 50 v2 - OS 50 Hyper - Spartan Quark - DS 650 - DX7
          Raptor 50 Titan SE - Redline 53 - Spartan DS 760 - DS 650
          Mini Titan e325 - Spartan DS 760 - 6100e - Huey Fus
          Phoenix
          Holder of 2 EGS
          Need a DJ? www.soundmachinedisco.co.uk
            hi scally ,i got rid of the t/g as soon as i could hover it made a great difference to the stability but i know what you mean about orientation the best way i have found is the use of bright colours,under the canopy and the skid supports are bright orange and my tail fins are yellow .
            Trex 550e dfc :-)
            t-rex 450s x2 /Raptor 50
            kyosho spree small plank
            bogey combat plank x2 woop
            http://www.cuffleymfc.co.uk
