Hi,
Im just learning to fly my T Rex XL HDE so am still at the hover stage! My setup is:
Align 420LF brushless motor
CC 25A ESC
Futaba 401 Giro
Futaba 6EXH
1x Impulse 11.1v 2100mAH (16C)
1x poly pro 11.1v 1800mAH 20C discharge 40C bursts.
I had one normal flight this morning. After changing the lipo I set out for another flight but the power dropped off and couldnt even get off the ground.
ESC set to fixed throttle 0, 75, 85, 90, 100
pitch set to 50, 60, 70, 85, 90
ESC is also set to auto Lipo which normaly cuts off at 10.5v
After the loss of power I checked both lipos and they were still above 12v
Just wondering if the ESC has given up! but as im a noob it could be anything!
I also did my end points with throttle at standard (0,25,50,75,100) with Throttle on full connected ESC and returned thottle to 0 to arm ESC.
Any sugestions would be grateful.
John (Grantham-Lincs)
CC 25A ESC
Futaba 401 Giro
Futaba 6EXH
