Hello people. I have a twister 3D that has a lot of vibration in a hover or flying around. Now the blades are a bit of a state but any other idea's what might do this?
have you crashed it at all, if so are you sure the main shaft is not bent?
TDR (in progress)
SAB Goblin 700
Vibe 90SG Vibe 500E
Kalt Baron30
Stefan
Check main shaft isn't bent then buy some new blades.
Wang, If you mean the Flybar, the main shaft may still be bent, double check
TDR (in progress)
SAB Goblin 700
Vibe 90SG Vibe 500E
Kalt Baron30
Spin the head round by hand and look at the swash plate if it wobbles your main shaft is bent and deff dont fly with damaged blades not just because of the balance but your own safety and any others that may be near you
Gaza07
Trex 500esp 6s Beast-X V3
Trex 600esp 12s Beast-X V3
A few Multi Rotors
sorry been a little busy. Well i purchsed it second hand and it's only 3 months old on the recipt but it had a hard life finding the floor. So i havent crashed it.
I have sorted the blade tracking and still no joy. back to Raptor for the time being untill i order the blades as no shops have them at the moment.
I have a few spare main shafts so il replace it too. Cheers all
Try A1 Models for blades, I never have any trouble
01206 572094, Dave will sort you out
TDR (in progress)
SAB Goblin 700
Vibe 90SG Vibe 500E
Kalt Baron30
