HelisimRC 'moving' with jerky image? Help?
  • #31
    You may want to try and update the display driver..
    ...actually forget the driver.. looks like it is the same version..
    andy
    ANdy - CDMFC
    Align 550 Beast X
    Proud owner of 3 x E.G.S.
    • #32
      Originally posted by acwman View Post
      so I take it that it is vista you are running..
      I'm still on XP, as and have only dabbled on friends pcs with vista.. so some thinks are a little different to me.
      I can't seem to see anything there.. and sort of running out of ideas. Can't believe that it is running so slow for you on the laptop.
      just doing a bit of searching.. and see if I can come up with any other ideas.
      Andy
      Hi Andy,
      Yes it is Vista that I am running.
      I'm off to bed now, so no need to invest more time tonight. Your willingness to help is very kind and, it shows a quality within you which is not often seen these days in others. Thank you.
      Thank you to every one else who has made efforts to help me
      Best regards,
      Tony
      Zzzzzzzzzzz
      My flying toys:
      Blade MCX
      Trex 500 esp
      Trex 600e 12s 44.4v
      • #33
        No problems..
        You may want to try a driver update I found here
        http://driverscollection.com/?H=Rade...By=ATI&dpage=3
        It is the top one.. display driver only..
        Your one looks like it is from 24/11/06, and the one in the link is released 10/9/07..
        whatever.. I hope you get it sorted.. although a simple sim, it will get you used to the sticks!
        Andy
        ANdy - CDMFC
        Align 550 Beast X
        • #34
          ..failing that.. you can always try the FMS Simulator
          http://n.ethz.ch/~mmoeller/fms/index_e.html
          ANdy - CDMFC
          Align 550 Beast X
          • #35
            No problems..
            Andy
            Andy!!!!!!!!!!!!!
            Wooo Hoooo!!!!!!!!
            YOU
            ARE
            A
            BLOOMIN
            STAR!
            THANK YOU!!!!!!!!!!!!!!!!!!
            Driver update worked a treat! Yippeee!!!!
            Thank you so very very much, if there is an award for being the most helpful member of rcheliaddict, you should get it this month!
            The sim no runs fast and smooth, ran fraps and even full screen I have well over 30fps.
            You're a top bloke, if I'm ever able to return the help you've given me I would be pleased to do so.
            My flying toys:
            Blade MCX
            Trex 500 esp
            Trex 600e 12s 44.4v
            • #36
              Thanks Tony for the big celebration for me!.. you've made me well chuffed with myself that it has worked
              This sim is actually better than when the very 1st sims were available.. and these use to cost nearly £200 back then..(Showing my age!)
              You may still want to try the FMS sim aswell. From my recollection, has quite a few different models and sceneries..
              Well happy flying on the sim, and sure the practice on it will come in useful.
              ANdy - CDMFC
              Align 550 Beast X
