HelisimRC 'moving' with jerky image? Help?
  • HelisimRC 'moving' with jerky image? Help?
    Hi, I've just got a lead and it works with my DX6i fine but the problem looks like the software is not running well on my PC.
    The image is very jerky, it is not smooth at all. One second the heli is on the ground and a second later it is smashed into the ground with no in-between images?
    When I manage to get the heli in the air, it moves forwards in large jerky leaps, not a smooth constant flow (I've checked youtube and I've seen that this is a smooth running sim, so there's something not right).
    Is this likely to be a PC problem? I've got a Dell running Vista, it's about 2 years old.
    Any help or sugestions will be appreciated.
    Regards,
    Tony
    My flying toys:
    Blade MCX
    Trex 500 esp
    Trex 600e 12s 44.4v
    it could be the graphics card in the Computer.
    Best thing to do is to go into the program setup screen, or options. Change the graphics to low, and see what you get there.
    This jerking is due to the graphics card not being fast enough to get a good frame rate from your simulator.
    Shay
      my dad knows alot about computyers as its kinda his job lol and i have learnt alot from and i would agree with shay
      as shay has said just need to lower the graphics quality hopefully
      good luck
      Matt
      Current = Blade mcpx v2 + DX6i
      Future = 1st - PL6 + PSU 2nd - Chase 360 3rd - DX9 4th - Who knows...there's too much choice
      One Eddie Gold Starsigpic
        Thank you for your reply.
        Do you mean on the Sim software or on my PC? I've already got the background resolution (on the sim) set to low.
        My flying toys:
        Blade MCX
        Trex 500 esp
        Trex 600e 12s 44.4v
          Sim software mate.
          any problems give me a shout, will be happy to help.
          Also lower everything to low, especially smoke quality, as this drains the ram loads.
          Shay
            Vista robs your machine of alot of power! If you are able to overclock CPU and GPU it may help tho beware will void your warrenty
              Sim software mate.
              Shay,
              Everything I can set to low (on the sim), I have. It is still running massively jerky.
              Any other ideas?
              Tony
              My flying toys:
              Blade MCX
              Trex 500 esp
              Trex 600e 12s 44.4v
                What's the spec of your computer?
                Brian
                More enthusiasm than skill
                And proud recipient of 3x sigpic
                  I haven't tried HelisimRC, but it does not really look like a very power hungry program. I would check that your OpenGL settings and play around with them.
                  ANdy - CDMFC
                  Align 550 Beast X
                  Proud owner of 3 x E.G.S.
                    You need to make the window smaller or run your desktop at a lower resolution.
                    If your desktop is running at high resolution and you maximise the sim window then its also running at high resolution.
                    Try and make the window for the sim much smaller and see if it works ok then.
                    If i does then you will have to make your desktop resolution lower so that you can run it smoothly at fullscreen.
                      run it in full screen mode at a lower resolution rather than windowed as running windowed will sap the framerate badly.
                      Futaba 9CP & 10CG
                        Dell laptop bought new about 2 years ago.
                        AMD Turion 64x2 Mobile Technology TL-50 1.6GHz
                        1GB RAM
                        32 bit operating system
                        My flying toys:
                        Blade MCX
                        Trex 500 esp
                        Trex 600e 12s 44.4v
                          I'm a pc thicko, how do I do that?
                          My flying toys:
                          Blade MCX
                          Trex 500 esp
                          Trex 600e 12s 44.4v
                            Thanks for your reply.
                            Even on the lowest resolution, it makes zero no difference? Even if I shrink the window down or have the sim playing full size, it is still mega jerky?
                            My flying toys:
                            Blade MCX
                            Trex 500 esp
                            Trex 600e 12s 44.4v
                              Maybe i should sell my PC to you :P and get a better heli lol
                              Seems like your PC cannot handle it,
                              But please dont overclock, 1 it voids your warrenty instantly, 2 you have to know what your doing, 3 you need to work out voltages ect, and it lowers the life span, not to mention heat issues. lol.
                              www.callumheli.co.uk
