Hi guys.
I tried to fly my Belt CP today but I have a problem with the tail / gyro
The gyro is a esky heading hold gyro.
On the ground with the blades spinning the heli stays reasonably straight and I can control the tail with the rudder but it is VERY sensitive.
But as soon as I lift off the heli spins clockwise in a completely uncontrolable way and I have to land.
Is there any way to test the gyro when the heli is on the ground?
The tail servo is setup as shown in the esky manual.
I did try to reduce the travel ajust on the tail to make the tail less sensitive but the servo travel is the same even if I change the ajust to 50%
I dont know what im doing wrong, or if the gyro is working properly.. is there any way to test it?
compatible.
