Hi all,
After a first flight and first crash "out of the box" with my first CP model I decided to research the best set-up for maximum learner stability for the HB CP2. This has raised a few of questions that the more experienced members may be able to comment on:
1. The pitch control - the following link is to an intersting mod where the rotor head is inverted. I have carried this out and blade tracking is much easier to set up and more stable. It seems to make sense. Any comments? http://www.rcgroups.com/forums/showthread.php?t=611437
2. Rear rotor - this is supposed to spin up evenly with throttle. On the bench, mine is "half hearted, sort of increases in stages (from about half throttle) but given some right rudder it spins up fine. Is this the norm or should I adjust the gain?
3. Is there any advantage to giving the flybar paddles some up pitch to improve stability, if so, how much? I've heard that it works on other models at the expense of manouverability (but that would be the point for me!).
Look forward to any feedback.
Thanks,
Herbie
Thanks,
Herbie
