Newbie here with a problem
  • Newbie here with a problem
    Hi all. I'm new to this lark, having been given a 2nd hand Venom Night ranger 3D. Actually, when I say I'm new, I'm coming back to this after a bit of a lay off - when I last flew a heli there were no such things as gyros and the Graupner (?) jet ranger was the one to have.
    Any how - back to my problem: The heli needed a new rotor head which was no problem,and I have got it all set up. Servos all work ok, however I have no power to the main or tail motors. The moors run fine if they are connected straight to a power source so originally I thought , Ah ha! the esc inthe rx is burnt out, so I replaced the whole rx with with one from a walkera 22E (The same, I believe) but the problem persists. All servos work fine, just no power to the motors!
    The venom instructions are pretty useless so I also got hold of the walkeea ones and what has further confused me is that I was led to believe that the rx incorporated the esc, but on the Walkera rx there is a point to connect a separate esc. So am I actually missing the esc.
    Confused a dazed now. And I thought a simple electric heli would be a good place to get back into this!
    Any thoughts and advice welcome. Cheers
    the esc is inside the 4in1 control unit. the spare esc port is for a brushless conversion .
    check that you are plugging the battery in after lowering the throttle and trim to there lowest position. and also the 3d mode switch is set to normal (up iirc)
      Ah ha, thanks for that. Also found that the dipswitches on the back of the tx were not in their correct positions so now I have power.
        Pacman - I notice your in Chelmsford, where do you fly?
        Regards,
        Jason
