I'm really stuck on setting up my GY401, it's been set before but it loses it's settings, but I've read about the memorization methods 1 & 2 and I don't know how or which one to do?
Right now when I power up the red LED flashes slowly but I have no rudder Gyro control, and I only dare to do low tail in at the moment because of this, but the tail is a bit lively which requires massive tail control while hovering
Right now on my DX6i the Gyro is set at SW-Gyro, Rate 0: 92.0% & Rate 1: 20%
but where it displays SW-Gyro the other choices are SW-INH, SW-F.Mode, (then Norm & Stunt are also displayed at the right of the screen next too the above rates on the left of the screen).
So when I read the GY401's manual where it describes how to set it up I'm completely lost as the discriptions they say you see on the TX's display are completely different from the DX6i's gyro display settings?
I admit I'm completely lost in this dept, the rudder adjust seems to be central when you move the Rudder stick left and right while on the ground, but with the LED flashing the manual says there is no rudder operation signal being input from the tranny, at this time, the rudder servo doesn't operate?
If anyone could kindly help me can you please write as simple as poss' as I know something simple is missing, but I'm somewhat intimidated with this area, and it's a total mystery.
I've seen the 450 fly when the gyro is set up and its as stable as a contra, where you can take your hands off the sticks and she just holds in the same position perfectly in control, right now it's a handful just holding her in tail in mode.
Many thanks for any help offered.
Glad your happy with the 401 mate!
