mode 1 and mode 2
  • mode 1 and mode 2
    is there anyway way to tell which mode i have without flying my heli yet? my left stick at the moment is in the bottom position..
    • Walkera 4#3B
    That would indicate that its a Mode 2 Controller - Throttle left
    Rgds
    Aidi
    700N 700E 550E
      looks like mode 2 ( throttle on left )
      MARK
      LOGO 500 V-BAR v5.2
      GAUI X4ii
      PROTOS 500
      MINI PROTOS 6S (stretched )
      GAUI X3. 6S
      JR DSX12
      14SG S-BUS
      proud owner of 2 x EGS
      www.bmmfc.com
        Mode 2
        Cheers Matt
          Three posts at 6:37
          Cheers Matt
            thanks for the very quick replies guys, i was just taking it apart when i thought..hold on, what if its mode 2 already???
            one more question, the rotor blades are flailing about loosely (ive only just got it out of the box! heh), am i to tighten the screws to fix them in the correct position?
            • Walkera 4#3B
              Yep, tighten them up. Not too tight so you can't move them though. A good rule of thumb i was told as a newbie was tighten them up. spread them out straight, hold heli by skids and give it a good shake up and down. Blades should move in the grips but not flap about.
              this was on a nitro, so if you have something like a 400 or 450 the same principle applies.
              Rdgs
              Aidi
              700N 700E 550E
                Rdgs
                Aidi
                this is just a baby 4#3B so its nothing big. the manual isn't the most helpful in the world... you'll probably be hearing a lot more from me.. cheers guys.
                • Walkera 4#3B
                  Lol. ignore what i said then... You can use the "User CP" button at the top of the page and add what you have to your signature.
                  A good read through the forum will give you loads of info on your heli as well as general info on what to expect as you "expand" into the hobby!!
                  Rgds
                  Aidi
                  700N 700E 550E
