Once again many thanks for all your comments. A lot of things to take into consideration. I've a feeling that unless I learn mode 2 thoroughly, as soon as a panic situation occurs, I will revert to mode 1, and automatically pull the right stick back to cut the engine, with interesting results!
John
If you're left-handed like me I seriously recommend Mode III.
It's the same as Mode II in terms of there is a cyclic stick, but it is on the left side instead (where my brain wants it). The right stick is throttle and rudder. I'm amazed this isn't standard for lefties.
Also, if you choose Mode III, you can still have mode I for planes as you can swap modes in the TX (both are right-stick throttle). As long as you are Futaba it can be swapped in seconds.
A lot of people give advice to go with whatever the norm is / the club uses, but Mode III "just made sense" so I chose that -- I don't want to fly other people's helis or have them fly mine, and if they do they can use their own TX (simply rebind the RX). You wouldn't write with your right hand just because everyone else does would you?
to fly with cyclics on the left stick, and rudder collective on the right - how have you set up the eccpm? do you have to use some pmixes? or did you open the back and swap the stick units on the PCB?
...or are all the stick functions assignable on your tx?
www.heli-extreme.co.uk a good club in south Sheffield 600n pro BeastX Align DFC head bls251, 3xbls451, align gov, 600d, 2in1 trex500, BeastX DS510 swash, Beast X cutr and carve head DS520 HK3026-1900, Align 425D blades, 5S4200 rev'trix, K&BDD dampers, AR6200 "450" superframeSTK, align DFC head v2tail, hk22281-8 on 3S 9650w9257gear commander 55A align 325D hitec digitals Tarot ZYX, AR6100e MCPX kbdd tail and blades, miniaviation bats
Interesting point, I like many lefties have just adapted to the situation, I dont think the right hand comunity realises somtimes how awkward things can be for left handed people. Ive done mode 2 now for 18 months so Im unlikely to change now though, However ive now got something else to blame for bad flying
And set the heli up on the Tx!
Unless you managed to get the heli setup on the original Tx using all stock Tx settings... heh heh
LOL yes I took that as a given
I actually meant simple in terms of you probably won't even need to swap the receiver to do it, if you're both on the same type of system you could swap pilot as easy as pressing a button (FASST makes it easy as you just press the button to bind, no need for a bind cable etc.)
When you know what you're doing it's only a 5 minute job to set up a new heli on a 6EX or an FF7 even from scratch. If you already have a good default 3-S heli model memory set up (as is wise, with all your preferred expo's, D/R etc) you'd only probably have to swap a few channel / swash AFR polarities and then BAM!, you're flying someone else's hard-earned grand's-worth of heli instead
Ive made the transition from mode 1 to mode 2 for helis couple of years ago, best way round it is loads of simulator time just to get used to it and then i put the baby undercarriage on my 450 and couple of short flights to get use to it and this is where the sim comes into its own it was then like second nature after that.
Hmm am left handed here .. but i use a mouse with the buttons on right handed config ... and also find flying helis and planks mode 2 easier than mode 1 ... or mode 3
Wow, now reading all that has made me change my mind again.
I'm sticking with mode 1 for fixed wing, definately, but may stay mode 1 for helis, depending how I get on.
Seems like we have all combinations in this community!
Mode 4 anyone?
John
Some time back I decided to have a full night (3 hours) on the Phoenix sim using mode 2 just to see if I could adapt quite easily.
I could fly the heli around no problem until I got into trouble then had a brain fart and couldnt recover it everytime..
This is exactly what happened to me, wanted to convert to mode 2 to progress further, managed to fly around in sim but as soon as something unusual happened, it was like muscle memory straight back to mode 1 brain and fingers without thinking. So mode 1 for me too. Have to fly F3C instead
Dave sigpic Proud owner of anE G S T-Rex 500ESP FBL Beastx
T-Rex 450SE V2 Futaba 7c 2.4ghz Cell-Pro Power Lab 8 & Cell-Pro 10S
I can imagine changing modes is actually even harder than learning to fly from scratch again - you need the reflex to be correct and it's probably better you don't know what to do yet rather than have to unlearn something too, especially in those unexpected moments where you need it to be instinct.
Interestingly Curtis Youngblood I believe using "single stick", ie I think this means he has the rudder as a twist on a big fat cyclic stick. Crazy! I read he has issues doing certain manouvres because of this but as he learnt on it there was no going back (and in fact it might help others as he has the collective all on its own).
I imagine it's probably a bit like trying to learn a new language, it's dead easy when there's nothing already there (we all do it naturally growing up) but learning a new one over the top is a lot harder. Or something
