newbie kent
  • newbie kent
    Like to say hi
    Ive just started flying this week with a chronos fb110 and I have the phoenix sim too.
    But having trouble with the heli side on and facing you etc, seam fine tail in but just cant get my head around it.
    I bet this has been asked 1000 times but is there tricks to help or just keep trying?
    Blade MCPX Brushless
    Ares Chronos fp110
    Welcome to the forum. There is no easy way to learn orientations other than practice, practice and more practice!
    the sim is a great investment and really can help without expensive crashes.
    if it was easy then this would not be such an addictive hobby.
    good luck.
    sigpic thank you.
      Welcome to the forum. Stick time, it's all about stick time. Stay with it and good luck
      XL Specter 700, Vbar Neo
      Synergy N606, 55HZ, Vbar Neo
      Oxy 5, Vbar Neo
      www.Hely-Shop.co.uk
      Lynx Heli Innovations
        Hi and welcome to the forum.
        Its all down to practise practise and more practise like Sheldrake said.
        With the orientation I found the best thing was to use a "clock" to slowly move round to side on and then nose in. Start at 12 o'clock (tail in) then move round to 3 o'clock by starting at 1 o'clock then 2 o'clock then finally 3 for right side hover. Take as long as you need on each point before moving round to the next number. For left side hover do the same but go 11, 10 then 9. And for nose in go 4, 5, then 6 and 8, 7 then 6. Hope this make sense...
        Rich
        SAB Goblin 700C - Black Nitro
        Flight Log
        THE MEDWAY MASSIVE
        WEBSITE FACEBOOK
          MIKADO VCONTROL
          SCORPION ​TRIBUNUS
          neXt
            Thanks , I thought it was just practice will ill keep up with the sim and my fb110 till I get my head round it before I get a bettet heli
            Thanks again
            Ares Chronos fp110
                Im in broadstairs heliguy uk
                Ares Chronos fp110
                  Welcome mate and just keep going on them sticks
                  Ronnie
                  Goblin 700 - HC3sx- Konny Pyro 700-52 - konny 120hv - bls 251 - bls 451s
                  Goblin 570 -demon 3sx - konny 100lv - xnova motor - Bk 7001s -BK 7005
                  Boggy combat plank - wot 4 - EFX - ECt ECt lol
                  FUTABA T14SG
                  PMHC - A128FREEFLY - Thurrock model flying club - TTI
                  GUINNESS WORLD RECORD PILOT 2012 & 2013
                  GRASS ROOTS 1st PLACE, FEB 2013 ( FOR BEST CRASH LOL )
                    Welcome
                    Try turning your body slightly in the direction you are pointing the heli so with the Tx in front of you you are kind of tail in again. Not much, just a few degrees will help.
                    Happy Landings.
                    David
                    Raptor 50. OS50
                    Mcpx
                    Blade 130x
                    Goblin 500
                      Hi Tony
                      Just came across your question, sorry if I'm late to the party. Like you are finding nose-in (with a quad) was a nightmare until I came across the following tip. Imagine you are balancing the end of an upturned broom on the palm of your hand (and let's face it, who hasn't done that). If the broom head falls off to the right your hand immediately goes to the right to maintain balance. If the broom head falls away from you you push your hand away etc etc. Substitue the broom head for your helicopter and your hand for the cyclic and after a couple of batteries with that in mind all should became natural. Good luck and let us know how you are getting on.
                        Originally posted by Euclid View Post
                        Hi Tony
                        Thanks for that i will try that when i get my heli back as i blow up the main motor, so as soon as i get it back i will give it a go.
                        Ares Chronos fp110
                          Just an update,
                          Been reading tip for new flyers and i see that most people use the pinch on the sticks. i use just my thumbs well i did... so i thought ill try it.
                          It was hard at first but now i would say i have more control and dont over react so much and also leaves my finger free to use the hold switch for when it all gose wrong. As i just use to drop down throttle( bad habit ive been told)
                          Any more tip or pages to look at would be greatfull.
                          Ares Chronos fp110
                            Almost everyone I know uses thumbs, think I know one person who pinches .... Fwiw.
                            Sent from my iPad using Tapatalk
