how much wind do you fly in?
  • how much wind do you fly in?
    im hoping to have a blast on my 450 tomorrow, but only hovered it a handfull of times on calm days so far. tomorrows wind is approx 8-9mph with 18-19mph gusts.
    what do you think?
    Goblin Black Thunder 700
    raptor e700 Night flyer
    Golbin 500
    Logo 550sx
    Rush 750
    Blade 550x
    and a load of broken micros!
    AIR SPORTS CLASS 2016 WINNER
    Recently 40 mph wind otherwise I wouldn't get out at all! Up to 15 mph usually.
    MIKADO VCONTROL
    SCORPION ​TRIBUNUS
    neXt
      30mph+ Love the wind to get some big ass loops.
      Raptor E700
      Raptor G4
        450 will be fine in those conditions. Mine loves it.
        Raptor G4
        TRex 700e
        ​2 x EGS
        For Sale:
          As above if you don't fly in it you wouldn't get a chance the way it's been. A few flights on the e700 today and although very windy was great fun
            You definitely have some big kahuna's as I tried with the 550e today, was getting blown all over the place,,not comfortable at all ,,,
            gave up and went home !
            Sab Goblin 570
            Sab Goblin 500
            500E Pro dfc
            450 Pro dfc
            Blade 300X
            DX9
              I flew my e700 today as well. Very windy but great fun!!
              James
              SEMAS Flying Club
                It wasn't comfortable but for blatting about its a gas. The 700 in fairness is a bit bigger than a 550 so has a little more stability and has the grunt to bring it back into the wind
                  Took my 550 DFC out last week in gusty conditions, i was crapping myself for the first two packs but after that it was a blast, i was loving the huge loops into wind.
                  I think it was nearly full negative at one point to keep the heli vertical at the top of a stall turn into wind and full pitch down wind
                  Managing the collective in circuits was fun, just as i thought i had the wind worked out, it would drop, increase or change direction!!
                  I usually land in normal mode but that wasn't to be as i was having to pull too much negative and would have ended up chopping the throttle. So i landed in idle up and hit hold once my skids toughed terra firma
                  Dan.
                  TREX 550X - Beastx HD Pro
                  GOBLIN 570 - V-Bar Neo Pro
                  Taranis X9D Plus
                  neXt Sim
                  AccruRc Sim
                  Proud wearer of 3 X EGS
                    Had a few on my 780 today. It's not that bad unless the air is turbulent with obstructions. Stick your nose in to wind and spool it up, shut down do the same and add negative to slow down quick. FBL controllers can make it a bit twitchy on the ground if its gusting.
                    MJ
                      Thinking about it, my 550e is the v1 with the 3g head, suppose it would fly better with a dfc setup?
                      Sab Goblin 570
                      Sab Goblin 500
                      500E Pro dfc
                      450 Pro dfc
                      Blade 300X
                      DX9
                        Not sure about that.....i find the 3G head a bit more forgiving and less twitchy than the DFC but i'm no expert.
                        Dan.
                        Taranis X9D Plus
                        neXt Sim
                        AccruRc Sim
                          Dan.
                          Neither am I !, my only experience with a dfc setup is on my 500 pro and so far,has only flown in calm conditions,,,will give it a go tomorrow and see what flys better in windy conditions,, the 600N doesn't count as I've only flown that for half a tank-still setting up.
                          Sab Goblin 570
                          Sab Goblin 500
                          500E Pro dfc
                          450 Pro dfc
                          Blade 300X
                          DX9
                            I'll fly in any wind really but I hate standing in it so I normally go home after 1 or 2 if it's that bad.
                              Have flown in winds where you need to spool up and get the heli in the air asap to stop it blowing over, makes for an interesting flight! As Maj said, good when it's not turbulent wind.
                              George
                              4x E
                              GS
