shuttle plus
  • shuttle plus
    hi i just registered this evening
    I bought a shuttle plus on ebay a few weeks ago and only just got round to putting it together tonight. It is 2nd hand and came with no instructions although i downloaded some for a shuttle z. Are these the same? Doesn't seem to be much difference if they are different.
    Anyway just to let you know i'm not entirely new to rc heli's as i've flown planes for around 10 years on and off. At my local club we have a variety of aircraft so over the years i've picked up a little background knowledge. I also bought a cheap sim to get the basics. I really was taken back at how tricky a hover is to do even on the computer. But i got on to it eventually.
    When building tonight i noticed that i have no "sleeve" (apart from the lugs on the body) for the rudder pushrod running down the boom, is this correct or do i need to source one. Also i've noticed, when activating the rudder by hand using the push rod, the tail fins "jump" very slightly when changing direction, which to me would indicate a little play. When moving the fins by hand there is a rolling motion, quite small, almost as if it is on a ball. Is this normal, does this disappear when fired up? There is also evidence that the boom had been previously glued in place, but to me this can't be right because surely i need the ability to put more tension on the belt as it slackens through use?
    Any other hints for checking a second hand heli? I've looked at all the ball ends on the push rods on the rotor head etc for excessive play and wear but all seems in pretty good nick. I might invest in a pair of new main rotors though as i have no idea to the integrety of these. Although there is little or no visible damage.
    Thanks for reading i know its a story!
    Hirobo Shuttle
    Hirobo Sceadu
    Black Horse Extra 330 .40
    Lots of spares
    Scuttle..... Ummmm
    Well You will get the same abuse as me... I got one....
    1. get rd of all the zbends they aint good enough for a heli
    2. get a tail mount for the rudder servo the standard linkage is miles long and prone to bind
    Then we can all use it for paint ball practice whilst you go buy a knight.....
    Steve.....
    Steve...
    Outrage RC Field Rep
      Now hold on one mo....thats not right...paintball practice is SOOOO wrong you should be ashamed.
      SHOTGUN PRACTICE MORE LIKE!!!!!!!!! LMAO
      www.lincsheli.com
        Hi and welcome.
        You will need the sleeve for the tail although I would recommend the NHP tail upgrade and mount the servo on the boom. It makes it much much better and reduces a certain amount of slop.
        The boom should NOT be glued in place as you are correct in that you will need to adjust the tension of the tail belt. Make it so that you cannot quite touch the other side of the belt when trying to push them together from one side. (Mine flew for over a year with no adjustment of the tension needed)
        Also, the standard exhaust supplied is not great. Take it apart, clean it and epoxy the two halves together then put the nut through.
        If its second hand, I would also take the main shaft and feathering spindle out and run them along a piece of glass to check they are straight. (The feathering shaft is between the two rotor blades)
        Finally, if in doubt about the blades, replace them. Its not worth the risk.
        Mark
        sigpicx2
        Airskipper 50 - For sale
