Just bougt me a Trex 450 pro
  • Just bougt me a Trex 450 pro
    Helo, i just bought me some Trex 450 pro. I am still new on this,so any comments would be welcomed.. Just want to know if i can set up my Dx6i to fly a fixed pitch heli??
    the 450 pro is a collective pitch model
    but the dx6 will fly both fixed and collective pitch models
    if you haven't got tthe manual for the dx6 you can download one from horizen hobby
    Hirobo Turbulence D3
    1/4 scale Vario Bell 47 G3
    1/3 scale Vario R22
    2012 LHC Scale Cup Judge
      As already mentioned, the 450 is a collective pitch, not a fixed pitch heli. If you've got a version with a 3GX flybarless unit, then you would need a 7 channel transmitter, or install a separate receiver. The 3GX cannot be used directly with 6 channel transmitters
      Sent from my iPad using Tapatalk - now Free
        Thanks big time
        @ Tomatwalden and Electricsceadu,Thanks alot for your wonderful infos. I understand the 450 pro is a collective pitch helicopter. Just that a friend of mine happens to be building a totally homebuilt fixed pitch helicopter from scratch. He's asking to know if he can use the dx6i for his heli... Guys, you needed to see this chap. So talented he fabricated his rotor head from aluminuim sheet,built his own swashplate,handcarved wooden blades,fabricated a oneway bearing... Amazing how he made everything from scratch. Here are pictures of his work,you can also read up his build thread here:Homebuilt Radio controlled Helicopter - Science/Technology - Nairaland learnt RCHA members are making a little donation for him here: http://www.rcheliaddict.co.uk/main-d...mentation.html
          I thought as much..
            Sorry that's not correct Tom.You cannot use a DX6 with satellites on the 3GX due to the way it assigns channels, however you can if you use a external receiver.
            Have a look here:
            http://youtu.be/SmBQRBlL_XU
            • Futaba T14SG
            • NEW!! TREX 500 Pro DFC 3GX V4.0
            • TREX 700e V1 Hybrid 3GX V4.0
            Team Mastercard
              I said the DX6i cannot be used DIRECTLY with a 3GX, which is correct. Yes, you can do it with an external RX - just as I did myself with my trex500 and 3GX originally. It's a messy setup though.
              If you reread my original post, you'll see I did say " or install a separate receiver "
              Sorry if I didn't make that clear. The issue fwiw is that the 3GX expects gain on channel 7.
                Are you OK with flying a collective pitch helicopter is my first question and are you building it from scratch or have you brought it second hand ?
