Trex 450 plus help
    I agree you will buy new main & feathering shafts in the future so buy them now and try them both. A good way to see if thay are bent when out of heli is roll them on clean glass, there should be no noise if straight. and don't forget the thredlock when replaceing bolts/nuts.
    flyingjacko
      Originally posted by RYAN CAIRNS View Post
      maybe i should take it outside an try fly it
      No,no check main shaft first to me it's shaking!!
      Regards
      Simon
        When you took head off, did you replace it back the same, = same link back on same link, if not could tracking again.
        flyingjacko
          Take all blade off and then spool it up to a higher head speed and see if it still shakes before buying anything. test and then take a part off one at a time and keep testing till you find the part/cause.
          Hope it goes well
          Paz
          Goblin Black Nitro
          Goblin 380
          Oxy 2
          Vcontrol
          Leicester Heli Flyers Club
            Originally posted by Goshawk View Post
            It's not hard take bolt out of main gears and head pop links off and pull it out 5 min job ill await reply in 20 mins
            thanks for the help. yes main shaft is bent at the top
            Love Music Production work as i produce Dance music but im reali getting into Rc Heli's. I have couple beginner heli's / phoenix sim & Im now looking to buy a Trex 600 Nitro.
              I would defo change the mainshaft.
              Raptor 30v2
              Skya 500 x 2 one to be Scale Bo 105
              Copter X450 x 2
              Trex 250 x 2
              Mcpx
              Raven wing.
              Suhkoi
              Anx Floater
              Radjet 800
              DX7
              Phoenix v4
              Proud to be member of SCHA
              Log Cabin for Hire in Snowdon.
              http://www.youtube.com/user/streetlu...s?feature=mhee
                yes iv checked and iv seen that its bent so just gona order 2 or 3 incase of other crashes
                  Just glad you didn't pop outside for a test fly
                  Regards
                  Simon
                    yes that prob would a been messy. part ordered now so hopefully it comes on wednesday
                    • #25
                      As flyingjacko says don't forget a very tiny bit of thread lock on screws for safety wen re assembling
                      Regards
                      Simon
                      • #26
                        yes ok no probs. thanks for help.
                        • #27
                          I had the same problem and supected the shaft. I took it out and put it in a cordless drill and spun it up . It shows up pretty good.
                          John
                          • #28
                            I know you already found the main shaft was bent, but you should be able to tell before taking it out by turning blades by hand and see if swash plate wobbles back and forth/ side to side. This can also show up worn bearings. ps you might as well order 4 or 5 main and feathering shafts, you'll need em soon enough
