Just checking my log on my mini v after one of my connectors came out in flight from a dry solder joint. I discovered alot of these error messages. Would these be related o the bad joint or is it a separate issue I need to look at? Heli was flying fine up until then.
Aileron sensor value out of range?
Probably the connector was intermittent so the corective action the servo was supposed to take wasnt senced by the gyro so it put in more movement..... and so on until it went out of range....
SteveSteve...
Outrage RC Field Rep
Wasnt even that, it was pretty soft actually. The errors go back a fair bit tbh so its possibly vibration as I have a lot of those too however the heli flies brilliantly but I'm do throw it about a bit so I'm certain that's why there is a lot of extreme vibration messages.Originally posted by LaurenceGough View PostRough landing? I know crashes technically can be called that!
Goblin 700
