powering carbsmart through gain channel
  • powering carbsmart through gain channel
    im trying to connect power to my carbsmart at the mo.theres two ways i can go about this one being a y-lead through aux2 and the other using the +- on the gain channel.
    my problem is that i dont want to use a y lead as it makes for a messy wiring job but im using a csm sl720 gyro and instead of the usual single signal wire going into the gain channel,csm gyros use a three wire lead going into the gain channel.
    so my question is can i still power through the gain channel by cutting the +- wires out of the gyro gain lead or do they have to stay?
    hope this makes sense
    Avant mostro 700E
    Avant mostro 700 Nitro
    member of :
    South cheshire heliaddicts
    are you running a gov???
    the gov only needs the sense wire not the + - so remove the + - wires from the plug and put your carb smart wires into it,, job done this how i did mine on my 600n
      yes,revlock30 through aux 2
      Avant mostro 700E
      member of :
        my first post edited mate,,
          or revlock dont need to be on aux unless your running 2 different rev ranges so you can do away with the aux bit of the gov but it will still give govorning to engine,
            never thought of that ,cheers
            so i could do this through aux2 and it wouldnt affect anything ,i wouldnt have to alter any tx settings?
            Avant mostro 700E
            member of :
              do you mean by removing aux or by useing the wires??
                sorry, by using the wires.
                Avant mostro 700E
                member of :
                  no it will not upset anything,,,
                    but just double check before you sart/fly your heli,!!
