Having set up my first Demon 3X and 3SX I have a few blanks that if someone could enlighten me I'd appreciate it. Maiden and subsequent flights have been superb very happy but questions on the following.
If you have active channels for gains on the head and tail the RC page values change. Does the unit take these values over the slider value in the tail/rigid page?
On the 3SX when you have tuned up the Rigid side of things and then tab to Horizon page. Select the appropriate tags for 3d.
When you adjust the head gain now horizon gain if you are in the middle up to 20% does this give you the same in flight performance as what you set in Rigid?
I'm not interested in SL more rescue so is it a case of just enabling -100% on your spring switch. Any expert settings etc what you use would be appreciated.
All I'm after is blatting around normally in Rigid with bailout on the spring switch.
Thanks,
MJ
Thanks,
MJ
