Hi everyone, I have noticed that when I switch flight modes i.e position mode normal mode and horizontal mode the swash plate moves to a position of back and to the left as I switch thru the modes, normal mode stays true to level but the other two modes Pos and HOR behave as mentioned. I have set up HC 3A many times, the heli is a Raptor Titan 50 ICM and the unit is mounted on the rear on a piece of Trex tail boom bolted across the tail boom supports and is very strong and stable. I made up a wooden block that is dead square both horizontal and vertical to the bench and applied the HC unit to it's bracket using this so that there is no issue with HCs orientation. So this is the question does this unit need recalibrating I know just about all there is to know about setting them up or have I missed something. I look forward to your thoughts. Thanks in anticipation Nigel.
