3G pitch adjustment question
    If I remember right from the manual they should be on the outer holes
    Trex 250 se, DFC, 3GX.
    Trex 500 esp, FBL, Beastx.
    Trex 600 nsp, DFC, Beastx.
    Compas 7HV, 120HV YEP, SK3 560, HV MKS, VBAR.
    Squall (less 1 wing).
    DSX9.
      No, I have double checked, it definitely on the second one away from center of servo arm. However, I have checked Trex500 flybar version, on this particular model, the ball linkage is on the outer holes.
      I guess may be this is due to the different mechanical on FBL and FB.
      Rui
        I am posting to thanks Vic.P, Gingerr6, Mslater and tourerjim who helped and given me advice on how to setup correct pitch range.
        I have finally setup the correct pitch range (+12 ~ -12) today. What I have done is taken the advice to shorten the three cyclic pitch rod, thanks very much for the above mentioned people who given me the valuable advice.
