I used to ground my booms back to the frame and engine mount. As you have the boom block, I think it should be safe to ground this to the mount. I would also ensure that the boom and your metal boom block have good contact, maybe by rubbing some paint away from the boom where it contacts the block.
I would also check you have good contacts on all the leads. Just feel that a 360 piro on a circuit flight sounds more than just a simple thing. Check that the lead connecting the control box to the tail sensor have good contacts. The pins in the socket of the sensor and control box can sometimes get pushed in inadvertently, so ensure this has not happened.
E.G.S.
for me
