Flybarless blades
  • Flybarless blades
    Hi does flybarless blades makes a differance or should i just stick with the normal blades at the moment am using CY SB blades
    Do what u do best
    DX7 and DX8
    Phoenix sim
    And plenty of spare parts
    radix stick bangers are very light weight which makes flybarless systems very very responsive i use radic fbl blades they are good as are the std radix and std aligns come to think about it (for my 600esp and 700n)
      am using the blades on my t rex 700 should i go and get flybarless blades or stick to the ones am using now
      Do what u do best
      DX7 and DX8
      Phoenix sim
        ive not tried them so i cant comment however i do use the std align blades and they are good and i also have the radix flybarless 690's which are also very good and slightly better than the align jobbys
          Hey.
          With the 3G fitted to my 700N originally I was running 690D's which were working well, not too lively but chuckable enough.
          Now I've moved the same gear into my new 700E I am running the dedicated Align 690 3G blades that are heavier to suit FBL better. I don't think these feel quite so edgy as the 690D's but they can certainly be made to move in aggressive 3D.
          Auto's are understandably better and so to is the hovering, especially in any wind.
          I've not tried any other FBL blades as yet to compare them to but am hoping to try some Edges or Radix's for a comparison.
          Ian Contessa
          Coolice Power Supplies
            Yes they do make a difference, as said SB's are very light are not really great for FBL helis at all.
            Get some EDGE blades and feel the difference for blades made for FBL . I find them more stable but with V-Bar V5 there isn't a great deal of difference as this system tries it's best to make all blades perform the same regardless.
              ok thank u
              Do what u do best
              DX7 and DX8
              Phoenix sim
                FBL blades has an outter COG and the heavier weight.. Benefits already mentioned
                I've got some Edge FBL on mine.. At first I didnt like them at all.. Now i've messed around with the Beastx Settings.. they are great!.. Much more stable in flight compared to 600D's.
                Eddie
                Velocity 90 FBL BeastX V3
                Trex 600 LE FBL BeastX V3
                Trex 500 EFL Pro BeastX V3
                Fusion 50 FBL
                VBar
                All powered by a DX8
