3g gone bad?
  • 3g gone bad?
    Flew my 3g today well tried to
    it's all was rolling to the left
    I have had 58 flights and not changed any setting latterly
    Is the sensor dead?
    what should I do?
    Cheers Paul
    Citizen #42
    Buy a Mikado V-bar?
      check the plugs. a mate of mine had a model go in it had lose pins in one of the plugs. it was flying fine then just let go.
      Trex700E sold
      Dragons450 gy401 s9257
      Mcpx
      JRDSX9MK2
      coolice Power Supply
        stop drinking cider, mate
          Check the head assembly and all links.
          We had a guy trying to fly his 3G on a 700, it did a really nice "Shakey sticks" ! and frightened the pilot to death.
          The cause was isolated to the grub screw on the elevator control bar (the one that goes through the frames towards the front. The grub screw was totally missing, and looked like it was never loctited . the elevator arm would move across between the frames.
          Once grub screw was replaceg the heli flew fine, but the pilot needed replacement kacks
          Janek
            my freind had this on his fbl, he was changing the gain to try and sort it, it would change from flight to flight, he took it off and had a FLYBAR refitted
            Chris 'CHUNK' Newby
            ALIGN-TREX.CO.UK team pilot
            LYNX team pilot
            SPARTAN team pilot
            Dx18
              DONT YOU DARE DO THIS TO ME!!!!!!!!! your fault i have 3g now your telling me its failling....
                Is this another case of Align beta testing??
                  Hey.
                  Apart from a possible sensor issue did you perhaps move the model during it's power up?
                  Could the servo horns have slipped a spline on the servo shaft during flight or transit?
                  When you power on the 3G does the swashplate stay level?
                  Now to a bit of tongue in cheek as I know the Mikado boys love giving it out ;-)
                  If you did ever decide to switch flybarless controllers why would you go Mikado when you can go TotalG now instead :-) LOL
                  I must admit as an experiment I'd certainly like to try all available flybarless units just so I know what each is and isn't capable of.
                  Ian Contessa
                  Coolice Power Supplies
                    Total G does look bloody good
                    Besides i'm a flybar fanboy
                      Funny how many people slag Align stuff off and the 3G when they haven't tried it.
                      I was liking the 3G more and more hope I can find the problem.
                      Thanks to the people that tried to help
                      Cheers Paul
                      Citizen #42
                        Ouch lol
                          Paul.
                          When you initialize the whole heli from scratch does the swash still sit level.
                          As coolice says maybe one of the servo discs has moved a notch on the splines.
                          This has certainly happened to me twice now using the plastic 3G discs.
                          Its worth a look.
                          I have changed all mine now to the metal upgraded ones.
                          If not try a different cable from the controller to the sensor.
                            I had it with all the buy this your stuff crap.
                            I am having a small problem with the 3G which I want to fix. That's all
                            Cheers Paul
                            Citizen #42
                              Thanks Tim
                              Swash looked good it field.
                              Tried it on 2 flights felt like it was going to roll left in to the deck at any point.
                              Cheers Paul
                              Citizen #42
