setting up a fl760
  • setting up a fl760
    hi all im trying to set up a 3g on a 250 and to be honest its 90% guess work (I have huge trouble with instructions) I don't understand any of it
    ive tried to follow what I can and have just done a rough start i.e by eye as I have no tools for the 250. I think the best art works but tail set up I go through it (seems u have to be quick at remembering) or u have to keep starting again spool it up and tail is 100% dead? confused.
    also whilst setting up speed control gets hot while in hold. is that normal?
    I know being as stupid as I am when it comes to manuals and stuff I guess I should just go get a vx1n lol but after paying rent I just dunno if I can manage it
    what do you lot think shelf heli sell 3g until I can afford Spartan or is there a real simple idiots guide any help would be awesome as you know what its like when ya get a new toy :P
    cheers terry
    cheers terry
    Hi Terry.
    When it comes to setup, specifically levelling the swash plate, I do so by eye. You just need to find the reference points to help you make sure it is level when at mid stick.
    Do you have the tail wires coming out of the 3G's main box plugged in correctly? The 3G has separate circuits for the cyclic servos and the tail control & single gain wire.
    Most ESC's with built-in BEC@s you will find get a little warm during use, I have found them to get more so if they are on the ground and you are not moving many servos at once to make use of the power the BEC is delivering. So unless it's so warm you cannot keep your finger on the ESC I wouldn't worry.
    There are videos on YouTube that walk you though the 3G setup, more precisely the DIR setup mode you need to enter to setup collective/cyclic limits and FBL gyro directions.
    To be honest I would just read through the manual a few times and follow that through step by step, as it is quite simple once you've done it. I cannot remember for sure if the PC software also has a walk through section that you click through step by step while following it. It's been a while since I've setup a 3G, but I know the 3GX does for instance.
    I may have to reinstall the PC software to refresh on this.
    Personally I'd say stick with the 3G for now, I think if you're struggling with this a Vortex may be worse as there is more options to go through, although it has it's own interface unit that helps.
    If you get stuck give me a shout with your questions and I'll do my best to help.
    Have a read here to; http://rchelicollective.com/viewtopic.php?p=31300
    Ian Contessa
    Coolice Power Supplies
      I got vortex on 2 helis working just need tweeking the 3g was on the 250 all set up but unfortunately for me I fly hitec not spectrum so literaly just swapped rx over.
      I did the tail set up with end points set and all but no gyro action or rudder I have another go tomos as im in agony and give up lol I seem to be better with pc setups and lcd devices flicking buttons on car esc's is ok but man this throws me lol
        Hey Buddy.
        Ah, so you know the Vortex. In this case the 3G will be very different, not more difficult as such just a different approach to setting it up. For the basics you won't need a PC, but to then tune the flight feel better one will be needed. I have a lot of settings for the 3G, so I am sure my 450 ones will suit the 250 nicely eliminating a lot of messing around.
        With the tail, I'm assuming that while you where in the tail gyro menu (press and gold set button while powered) that the tail worked as required, but out of DIR it's dead?
        Keep at it as I am sure you will find it ok once setup and flying.
        Ian Contessa
          Buy an AR7200BX these are very easy to setup and it has a built in receiver
          Phil
          Align MR25 Racing Quad
            Yeah gonna have a try again later probly done something supid for tail not to work .
            Ar beast x thingy the built in rx no advantage as I fly hitec. If I had spekky then it was all set up lol
            Cheers terry
              thanks for your help guys I figured out the tail but cant stop it tipping probly something simple but its now up for sale think it will be cheaper to buy a vx1 or put a fb head on it
                Hi Terry,
                I guess maybe a silly question, but you have got the blue rudder sensitivity wire pluged into your gyro gain channel on the receiver ? Otherwise it probably won't do anything as the gain will be to low.
                If you get stuck you're welcome to come over to my place as I've got the 3GX dongle etc and experience of setting them up. Looks like I'm about 26miles away from you.
                (I'm Martyn with the Silver Elise BTW)
                Martyn
                Blade 400, Outrage G5 FBL, Align 500/600
                DX7, DSX9
                  If it's tipping it's almost certainly the swash isn't level. Or if you're running V3.0 you might need to go up to V3.1 or V4.0. You may find a quick take off will avoid the tipping if the swash is level.
                  Just one more thought over time my old 3G unit often starts to tip and re-running the initial Elevator / Aileron setup usually fixes it and of course your trims need to be zero as well
                  Martyn
                  DX7, DSX9
                    I used to have 3G on my old 250se & flew really well but you do need to set the gain pots first to get a steady lift off, then adjust parameters to suit your flight.
                    It's important to be sure swash is level at all 3 stages of neg, zero & poss with least amoung of sub trim before going through dir setup, then when in dir set elev & aile between 9 & 10 degrees cyclic & if you've got the tail sorted the heli will fly nice.
                    • Flickr Through My Pictures.
                      Originally posted by martynv View Post
                      Hi Terry,
                      easy tiger how you doin I did sort the tail and you are on the money I had to go into gyro menu and move the gain up lol all sorted
                      thanks for the comments but I am not doin a fast take off it scares the shit out of me. i was prepared to give it time but the fact that it scares me and the stories that put me off fbl in the first place i think it needs to goto a home that can give it love as it were. i just have to sell some stuff and put a vx1n on or a brain as they werk out the box
                      please don't get me wrong i REALLY appreciate your help on this but i just don't understand the instructions (im a need to be shown then doit my self person or i don't learn) andy from sandy can vouch for that he taught me well (thanks andy) if any 1s interested make me an offer on it i just wanna fly gonna stop rambling as im proper hammered :P need to go price up some blades n bits for next week lol
                      oh yeah the tipping baffles me steer it on the skids with cyclic fine go to take off gently and bam she over it will be something i done wrong :P
                      all the very best terry
                        The headspeed on a 250 is a bit scary isn't it. I had a servo motor go on a HK-250 at work when I was testing it and it hit the window sill so fast I couldn't catch it ! Made a lovely mess of the head an bent the boom too.
                        I think the 3GX is a bit of an aquired taste, but they can work really well once setup. Any way have fun and I hope too see you again next year.
                        Martyn
                        DX7, DSX9
                          oh yes il be there just been out with the 700 2000rpm headspead 13deg pitch and strong wind DAMN what a rush I would love to know how fast it was coming out of banked turns.
